15 Over Bore On Hp 500 >
Old 10-11-2006 | 06:31 PM
Default 15 Over Bore On Hp 500
Anybody Know Anything About A 15 Over Bore On A Hp 500.
I Talked To A Few Guy's And That Does Not Seem To Be The Norm,
Any Info Would Be Great .
I'm Looking At Buying A Boat That They Told Me The Motor Had A 15 Over Bore So I Was Just Doing Some Research On It
Thank's For All Your Help
Mike
mikebrls is offline
Old 10-11-2006 | 07:03 PM
Default Re: 15 Over Bore On Hp 500
Just Talk With The Builder Of The Hp 500 And He Said They Where 60 Over 502 Bore = 515 Cubic Inch .
Sorry My Mistake
Is That Still Ok ?
Thank's
Mike
mikebrls is offline
Old 10-11-2006 | 07:43 PM
cuda's Avatar
I think 60 over is about the end of the line for the engine. If you have to bore it again, I think you'd be SOL.
cuda is offline
Old 10-12-2006 | 12:00 AM
If it is a gen VI 502, which it should be, the bore can be taken to 4.600. It is at 4.530 now. Why was it bored .060 in the first place. Usually, a standard rebuild should take it .030 over. It may have broken in the past and had enough cylinder damage to require .060 to clean it up. You need to ask why it was bored so much. May not be a big deal. You still have plenty room to go in the future. Eddie
Young Performance is offline
Old 10-12-2006 | 08:04 AM
rmbuilder's Avatar
MarineKinetics
Mike,
For a std. Gen VI non-Bowtie block:
4.470" Std bore
4.500" Max overbore recommended by GM
4.530" With sonic check and minimal core shift
4.560" Been done with mandatory sonic test and zero core shift. Not recommended.
If this influences your decision on purchasing the boat I would do so with the knowledge that, for all practical purposes, the block is at the end of its service life short of sleeving it.
Bob
rmbuilder is offline
Old 10-12-2006 | 10:03 AM
mcollinstn's Avatar
yep. any 502 with jugs over 4.500 needs to be explained.
mcollinstn is offline
Old 10-12-2006 | 02:20 PM
Thank's Guy's
mikebrls is offline
Old 10-14-2006 | 03:42 PM
Strip Poker 388's Avatar
Rob
I have one motor that's 60 over and one hole with a sleve in it.I don't see any probs with this combo on 2 summers at boost yea it might have a little more blow by but the leak down looks close and there s only about 20 hp diff between the 30 over motor . I don't think the bore diff in 30 and 60 makes much hp diff .if it gets to bad ill replace the block and go back to 30 over..I would rather be at 30 not 60.
I would not make that a deciding factor over not buying a boat but depends on what boat and price range the boat is , I guess a new block is 1500.or used 750?.alittle labor so its not that much money on a 100k plus boat .The only thing that would concern me as to why the motor had to go over bore ,to me that means someone ran the shet out of it or there was just a parts failure??
rob
Strip Poker 388 is offline
gg10
2
11-20-2005 06:14 PM
MILD THUNDER
2
07-25-2005 10:13 PM
formulaF302
15
06-16-2003 11:49 PM
THRILLSEEKER
9
05-03-2003 02:12 PM
gene
2
03-22-2003 02:34 PM
