operating controls >
operating controls
operating controls
Old 10-16-2006 | 10:55 AM
Courtholl's Avatar
Default operating controls
have been out getting use to new 24. Have shifter and thottle; however, when I take my hand off the thottle it drops of. As a result, it makes it hard to adjust drive and tabs when getting up in speeds. I have not looked, but I am assuming I can tighten somthing on the back side of the thottle. What would I be looking for?
Wife and I were out yesterday, and we able to find some rough water. When out in the open we were at about 60MPH. Was trying to bring the drive up more, but started to walk a little. Wanted to use the tabs (have the larger K-planes), but could not take hand off throtle or wheel, so had to back off. Wanted to get tabs done and adjust drive more. i know I can reach 70mph, but not without being able to adjust everything. Anyinfo of what to look for totighten throttle up would be appreciated.
I like going fast, but honestly like getting in the rough stuff, and this thing is great in it.
Courtholl is offline
Old 10-16-2006 | 01:28 PM
Stormrider's Avatar
JC Performance Engines
Default Re: operating controls
which shifter system do you have?
Maybe it would be a nice upgrade project for the winter.
Stormrider is offline
Old 10-16-2006 | 09:11 PM
Just take out the 4 screws that hold the shifter/throttle down and lift it out as much as possible. The resistance is easily adjustable. Can't remember the specifics, but it only took me a few minutes to adjust mine a few years ago.
Griff is offline
Old 10-17-2006 | 07:06 PM
Elite Marine's Avatar
Griff is right. There should be some sort of friction lock that you can tighten. Newer controls use an allen head set screw, older units a standard phillips head screw.
Once you take th cover off you should see it easily.
Elite Marine is offline
Old 10-20-2006 | 04:55 PM
Courtholl's Avatar
Looked under the control panel. Looks like there is a flat phillips screw. About .25 to .5 in in diameter. Is this what I am looking for?
Old 10-21-2006 | 02:44 PM
Don't know for sure without seeing it. Giive it a turn and see if the throttle tightens up.
Griff is offline
Old 10-21-2006 | 07:56 PM
Do it in nuetral please!!
sha- mat
8
04-09-2012 08:03 PM
powerquest280
Sonic
15
06-04-2007 05:23 PM
goodstuff
Superboat
4
06-26-2006 08:35 PM
Pure Energy
8
08-02-2005 05:47 AM
96f350psd
2
01-10-2004 04:07 PM
