Denali with air ride?
Old 10-17-2006 | 03:32 PM
dyno's Avatar
Charter Member #655
Default Denali with air ride?
anyone towing with a Yukon Denali XL with air ride? Looking into putting the wife in one, how much tongue weight will it handle???
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 10-23-2006 | 02:55 PM
cfischer's Avatar
never trade luck for skil
Default Re: Denali with air ride?
7,000 lbs but doesn't feel comfortable.
cfischer is offline
Old 10-23-2006 | 03:18 PM
BajaRunner's Avatar
my girlfriend drives one, i wouldnt tow 7k with that thing.
BajaRunner is offline
Old 10-23-2006 | 03:48 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Probably rated for 7500lbs. with a Weight Distributing hitch.
If you upgrade the hitch to a Putnam XDR, you could be rated for 7500lbs. Weight Carrying.
HOWEVER, Thinking you are probably going to tow with your wife and loved ones aboard, and your boat behind you... think of the consequences. I would not want to tow more than 5000lbs. with that truck. That MAX.
Go for the 2500 if you feel you need the big GM SUV to tow.
Sydwayz is offline
Old 10-23-2006 | 05:05 PM
cfischer's Avatar
I just traded in my 05 3/4 ton Yukon with the 8.1 for a new one with the 6.2. ***** truck compared to my 05. Want my old one back.
cfischer is offline
Old 10-23-2006 | 05:06 PM
cfischer's Avatar
I also had a 02 Denali and would pull my 28' Cig with it and it was very uncomfortable. Felt like it was working too hard.
cfischer is offline
Old 10-23-2006 | 05:54 PM
jeff32's Avatar
I towed my 9000 pounds boat with a short 2004 denali and it was perfect. My best truck ever by far... But when I hooked the Formula on it... F 35-7, 1260 pounds tongue weight... starting to accelerate on stop or red light the front wheels would spin on asphalt very lightly and I could hear them spinning. Besides that... Best truck ever!
Attached Thumbnails Denali with air ride?-formula-35-7-1989-001.jpg   Denali with air ride?-formula-35-7-1989-004.jpg
jeff32 is offline
Old 10-23-2006 | 06:27 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Did you tow with the new one before you traded it in? Hell, I would have pulled right up to the dealer with my boat in tow. "If it tows as good as this one does, I'll buy it tonight." I actually took 2 different trucks home and towed with them on "afternoon test drives" One, a new Cummins Dodge Dually, and a nearly new Ford 6.0L Harley F250. Took them both back, and bought a 7.3 PSD Ford Dually.
I would not be afraid to do this. If a dealer/sales manager pushes back, walk away. If you are purposely buying a truck to tow a certain load, you need to know its capabilites before you own it.
Sydwayz is offline
mcraymond3
2
05-05-2008 08:00 PM
TeamSaris
2
03-08-2007 08:00 AM
unimog1300
1
03-12-2006 06:39 PM
bobby daniels
07-14-2003 11:40 PM
