What size carb do I need. >
Old 10-18-2006 | 10:10 PM
Hot Boat's Avatar
Team Dysfunctional
Default What size carb do I need.
On my current motor I am using a modified 850 holley that flows about 930+ cfm. Its mounted on a 454 with a 177 blower
If I re jet it would this carb work on a 502 with a 250 blower ???
If it aint broke .... I can break it....
Hot Boat is offline
Old 10-18-2006 | 11:36 PM
Default Re: What size carb do I need.
I would sure consider a dual 750 carb setup on that config. But what you have will most likely work, just watch out closely for a lean condition.
ghittner is offline
Old 10-19-2006 | 02:32 AM
RLW
I ran a Nickerson 1050 on my B&M 250/468 CI motor. Dean had it dialed in perfect. You would have no problem selling your 850 carb to a 502 or 540 owner.
RLW is offline
Old 10-19-2006 | 08:14 AM
Mike Paula's Avatar
When I set up a 509 with 8 71 I ran dual 800's. When I where questioning if it had enough carb. I was told to check for vacuum at the at the top of the blower/ bottom of the carbs. If there is vacuum need more carb.
Mike Paula is offline
Old 10-19-2006 | 09:31 PM
That's probably the best dam*ed info that I've heard regarding blower carbs and the need to not blower reference! I'm runnin' a 420 that everone said I'd have to blower reference my 750's. Not even close! Zero vacuum at WOT. Great explanation man!
ghittner is offline
Craig B
6
06-13-2007 05:54 PM
AIR TIME
17
03-09-2006 04:01 AM
CayFomula
2
09-02-2003 01:25 PM
homan
9
08-10-2003 08:07 PM
Fast Forward
10
05-22-2003 07:45 PM
