Trim Help
Old 10-19-2006 | 09:40 AM
BY U BOY's Avatar
Default Trim Help
All Right Guys I Need A Little Help Here.
I Changed My Harness And It Does Not Have Trim Indications Anymore. Is There A Way To Bypass And Just Hook It Up Directly Or Does It Need To Go Through The Harness?
I Trim By Feel And Really Do Not Care If It Works For Me, But If Someone Else Is Driving I Do Not Want To Worry About It. So If Any One Knows What I Can Do I Would Be Grateful. Thanks
BY U BOY is offline
Old 10-19-2006 | 09:45 AM
wrinkleface's Avatar
Default Re: Trim Help
Wow, when I saw the title I thought it should have been in the UC section!!
wrinkleface is offline
Old 10-19-2006 | 09:46 AM
BY U BOY's Avatar
I DON'T NEED ANY HELP WITH THAT KIND OF TRIM
BY U BOY is offline
Old 10-19-2006 | 12:11 PM
Wobble's Avatar
SORE MEMBER
It's a simple circuit, run a line from the sender post on the trim gauge through the trim sender and then to ground. I assume the dash wiring is still stock. If not there should be switched fused power supply to the plus side on the trim gauge and a ground on the gauge also.
If it reads backwards switch the wires at the transom
Wobble is offline
Old 10-19-2006 | 12:31 PM
Wobble's Avatar
SORE MEMBER
If your boat harness is stock as far back as the engine bay, look for the brown and white wire coming from the dash, (should be the same color on the back of the trim gauge sender post). extend this wire to the male connector on the trim sender and the other trim sender wire (female) should go to a good ground
EDIT, if it's real old the sender wire on the gauge might be purple
Wobble is offline
Old 10-19-2006 | 12:36 PM
BY U BOY's Avatar
WOULD IT BE BETTER TO TAP INTO THE HARNESS THAT LEADS TO THE DASH? THE PIG TAIL FROM THE SENDER IS STILL THERE. TWO BLACK WIRES WITH BULLET CONNECTORS. ROSS IS PRETTY SURE THAT IT IS A BROWN WIRE WITH A BLUE STRIPE.
BY U BOY is offline
Old 10-19-2006 | 12:40 PM
Wobble's Avatar
SORE MEMBER
Tan and blue is normaly the alarm circuit, (resevoir bottle, low oil pressure and high water temp. Tell Ross to grab another coffee
Did you cut off the old mercruiser engine harness plug? if so this is where I would look for the brown/white wire.
Wobble is offline
Old 10-19-2006 | 12:50 PM
BY U BOY's Avatar
Mark You Are Right The Old Harness Has 1 Brown With White Stripe And A Female Connector Then 3 Tan With Blue.i Will Extend The Brown/white And See If That Works. Thanks For The Help Mark/ross
BY U BOY is offline
26sonic
Sonic
8
06-23-2009 09:14 PM
H2X BOSS
1
06-19-2007 05:45 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
