Go Back  Offshoreonly.com > Owners Forum > Sonic
trim master trim tabs for 26 sonic >
Old 04-28-2008 | 06:08 PM
26sonic's Avatar
Default trim master trim tabs for 26 sonic
these trim tabs where used on 1998-and some 1999 26 sonics. looking to buy 1 trim tab cylinder( dual set up) one of mine is leaking . trim mater is out of buisness and need to locate one or possibly another brand that will be a direct replacement don't want to change whole set up . any body out there that can help ?
26sonic is offline
Old 04-29-2008 | 10:29 AM
Just spend the money and put k's on it,I had them on my sonic and switched to the k's.Had nothing but problems,I accually snaped a cyl piston(Plastic junk).Sorry I really didnt answer your question....It just brought back a bad memories...
creeper is offline
Old 04-29-2008 | 10:51 AM
Registered User
I can confirm that "K-Planes" on a 26 Prowler are perfect....They work great...
rangerrick63 is offline
Old 04-29-2008 | 12:35 PM
26sonic's Avatar
creeper do you still have these parts ?
26sonic is offline
Old 04-29-2008 | 01:32 PM
Sorry,I dont....I'll ask around for you....
creeper is offline
Old 04-29-2008 | 07:54 PM
GO4BROKE's Avatar
Can the cylinder be rebuilt? You might be able to find someone local. And keep an eye out for used K planes. Sometimes people upgrade to larger ones.
[img][/img]
GO4BROKE is offline
Old 06-22-2009 | 08:45 PM
I fix my leaking cylinder very easy
u need 1 actuator piston seal 20X32X6 and one O ring 20X6
it cost me $12AU
i hope this will help you it is on smole trim tabs i got 6m boat
cheers noluck71
noluck71 is offline
Old 06-23-2009 | 07:36 PM
26sonic's Avatar
The cylinder is a plastic materisl and cracked !
26sonic is offline
Old 06-23-2009 | 09:14 PM
My did not crack and i did not have tool to pull the part i just use wise grip to take the cap off not much in there
piston and rod and two seals
noluck71
noluck71 is offline
dloftis
Baja
8
03-12-2009 08:08 AM
26sonic
04-30-2008 03:08 PM
ItsPeanut
1
04-14-2008 06:23 PM
26sonic
04-03-2008 03:37 PM
26sonic
Sonic
1
04-03-2008 03:11 PM
