XR drive
Old 10-22-2006 | 06:01 PM
Magnum25's Avatar
Default XR drive
My boat currently has a bravo1 outdrive.Can i change that to a baravoxr drive without changing the transom assembly?
Magnum25 is offline
Old 10-22-2006 | 06:17 PM
Default Re: XR drive
yes
CN24 is offline
Old 10-22-2006 | 06:18 PM
BRUCE SEROFF's Avatar
i believe you will have to change your gimbal bearing
BRUCE SEROFF is offline
Old 10-22-2006 | 06:24 PM
Elite Marine's Avatar
You'll need a larger gimbal bearing and the trim limit spacers. The U joint for the XR is larger and without the limits, I think you can ruin the U joint.
Here's the part numbers and pricing from Mercruiserparts.com
26-88416 SEAL-OIL $18.53
30-862540A3 BEARING ASSEMBLY $73.07
11 61075 RING-TOLERANCE $7.81
15768A3 SPACER KIT $5.37
Kirk
Elite Marine is offline
Old 10-22-2006 | 06:39 PM
Smitty's Avatar
Call Marc at Bam Marine. Merc now makes a kit that has everything you need for around 85 bucks.
Smitty is offline
Old 10-22-2006 | 09:58 PM
I bought 2 xr drives to replace my standard bravo!Everything bolted straight!I removed each bravo and slid the xr right in!No worries!
JJONES is offline
Old 10-23-2006 | 06:38 PM
Mr Gadgets's Avatar
Charter Member #601
It depends on the input shaft ujoints. The new gimble bearing is offset by .050" and the trim limit spacers keep the drive from tilting too far when the old style large ujoints are in the shaft. I have not tried it with the new shafts, but the joints are smaller... So I would not go without the spacers until someone measures the clearance.
Hope this helps..
Dick
Mr Gadgets is offline
Full Force
Drives and Lower Units
3
10-15-2007 07:29 AM
Canada Jeff
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
