OMC Ignition 90 350 King Cobra >
Old 10-23-2006 | 11:24 AM
Big Block Billy's Avatar
Unhappy OMC Ignition 90 350 King Cobra
How reliable is the distributorless ignition system on a 1990 King Cobra 350 Chevy ?
Do the flywheel sensors go bad ?
Can I remove the rubber plug and install conventional ignition ? There must be a driveshaft to turn the oil pump.
I really try to stay away from anything except Merc inboards and Merc I/O's
Big Block Billy is offline
Old 10-23-2006 | 12:46 PM
FOUNTAINATLAST's Avatar
Default Re: OMC Ignition 90 350 King Cobra
That ignition is very releiable, plus it has a knock system built into it. The plug your refering to is the oil pump drive shaft, if you take it out the bottom looks just like a distributer. You can just pull it and add a distributer, and coil system but I would stay with that stock system...
FOUNTAINATLAST is offline
Old 08-03-2013 | 12:22 PM
If this thread can be resurrected... I have this same model year setup (1990 OMC King Cobra 5.7) and I need some help tracking down replacement coils and sensors. I have been searching for a year...
90predator is offline
Old 08-04-2013 | 09:20 AM
iirc you can't buy much for that old ignition ..Since it is a chevy motor you can always convert to? ( lots of choices ) How about converting to Merc Thunderbolt. Cheap and EZ
motor is offline
ciaoderhead
Drives and Lower Units
12
06-02-2023 03:56 PM
yesrej
35
06-10-2022 01:48 PM
tassie boy
1
08-17-2007 06:28 PM
onesickpantera
9
08-09-2007 10:43 PM
merlyn1965
08-16-2006 07:02 AM
