High Perf. Engine Parts vs Parts >
Old 10-25-2006 | 04:22 PM
Elite Marine's Avatar
Default High Perf. Engine Parts vs Parts
I'm deciding on the parts for my engine build and the price of the T&D Shaft Rockers is crazy ($ 1,400.00) are they worth the extra $ 500.00 versus Jessel or Crane Shaft Rockers?
Same issue on the crank- Callies Dragonslayor vs Calles Racmaster?
I guess while I'm at it rods - Lunati, Oliver, Eagle?
I'm planning on under 900 HP with an M-3 Procharger.
Elite Marine is offline
Old 10-25-2006 | 06:57 PM
Default Re: High Perf. Engine Parts vs Parts
We have run the Jessel system for the past 4 years with no problems. In fact this is the only thing that has not caused a problem.
HighPriority is offline
Old 10-25-2006 | 07:33 PM
Jesel > T&D
TwinTurboStroker is offline
Old 10-25-2006 | 08:16 PM
I like the decision based on price, but why are the T&D so much more and what is the benifit of the oiling system if Jessel doesn't use it?
Old 10-25-2006 | 08:35 PM
Vinny P's Avatar
I hate the winter!!
Kirk,
I was under the impression that T&D shaft rockers were less expensive and equally as good as Jesels. I am thinking about upgrading to T&D's if I go to a solid cam this winter. By oiling system, I assume you are reffering to spring oilers. If so, the extra supply of oil is to keep the springs cooler thereby increasing their durability
Vinny
Vinny P is offline
Old 10-25-2006 | 08:58 PM
I understand the spring oilers, but the price of T&Ds is $ 1400 verxus about $ 899.99 for Jessels. Do you need seperate spring oilers for the Jessels?
Old 10-25-2006 | 09:12 PM
Vinny P's Avatar
I hate the winter!!
That cant be. Be careful when pricing shaft rockers, they make different grades of rockers. The cheaper ones are not worth it. I am positive if you were to compare comparable T&D to Jesels, you will find Jesels to be more $$$.
Vinny P is offline
Old 10-25-2006 | 09:36 PM
berns29scarab's Avatar
i've always been a crane gold guy...i believe thats what Merc uses in there blue motors no ?
berns29scarab is offline
Old 10-26-2006 | 12:03 AM
articfriends's Avatar
Kirk,before I ordered my T&D rockers I looked at Jesels. The 899$ ones are their entry level low grade ones,I think they are called sportsmans. They have different grades,the sportsmans would probably last forever in a hyd roller cam motor but I didn't want to take any chances. I like the fact the T&D's have a spring oiling option. If you buy the middle of the road Jesel's they are close in price to the T&D's,Smitty
articfriends is offline
Old 10-26-2006 | 12:35 AM
ratman's Avatar
these are pedestal type rockers that are far more durable than cranes stud mounted rockers, these are for extreme lift cams, im running .720 lift solid roller i went with the mid grade 1200 buck jesels.
ratman is offline
