Need Survey Wood Bridge,VA >
Old 10-26-2006 | 11:57 AM
Tony Montana's Avatar
The BAD Guy
Default Need Survey Wood Bridge,VA
Posting this for Mike. He needs a survey done asap in Wood Bridge,VA. He wants someone who is good and can do comp/leak down test on a 2004 38' boat w/ twin Merc 525 Efi's. Also moisture test. Call 954-709-7191.
Tony Montana is offline
Old 10-26-2006 | 12:34 PM
texaschopper's Avatar
Default Re: Need Survey Wood Bridge,VA
call one of the large lenders like Beacon Credit. They have guys all over the Country that do surveys for them and can provide you with a few names
texaschopper is offline
Old 10-26-2006 | 02:09 PM
PM HUGH ............ "HPOFFSHORE"
HE WORKS FOR A PERFORMANCE DEALER AROUND THIS AREA AND I'M SURE WOULD BE ABLE TO HELP YOU....
HOPE THIS HELPS, PAT
Spicy is offline
Old 10-26-2006 | 05:25 PM
45sonic's Avatar
On a 386 Sonic??
Call either Hugh as suggested earlier or Frank Marchone (Active Thunder) for a suggestion.
Frank: 410-320-5307
45sonic is offline
Old 10-26-2006 | 09:31 PM
Call Fred at True Headings 703-517-1281. I know he has a moisture meter and he might know someone to do the leak-down test. He does a real professional survey. I just had mine done about a month ago. Tell him Mick sent you. Hope this helps!!
Micker 31 is offline
grads2112
Jaguar
12
10-28-2005 08:35 AM
grads2112
Jaguar
8
09-19-2005 05:10 PM
Lofty
07-27-2005 01:52 AM
Lofty
Poker Runs and Boating Events
0
07-21-2005 04:37 PM
grads2112
Eliminator
5
07-08-2005 02:51 PM
