502 ram jet cam >
502 ram jet cam
502 ram jet cam
Old 10-27-2006 | 02:19 PM
Default 502 ram jet cam
does anyone know for FACT what cam the chevy 502 ram jet pif injected 500 hp crate motor has in it and if it is suitable for marine use ? it uas a 110 centerline... ... i know that much about it...
stevesxm is offline
Old 10-27-2006 | 02:37 PM
BY U BOY's Avatar
Default Re: 502 ram jet cam
Are You Talking About The Zz502/502.
BY U BOY is offline
Old 10-27-2006 | 02:52 PM
rmbuilder's Avatar
MarineKinetics
The Ramjet and the ZZ are the same cam.
224º/234º @ .050"
.527"/.544" valve
110º LSA
rmbuilder is offline
Old 10-27-2006 | 04:58 PM
BY U BOY's Avatar
I Am Using That Same Cam With No Problems.
BY U BOY is offline
Old 10-27-2006 | 07:39 PM
thx... at 8500 seems like a hell of a deal even w/ having to marineize it.
stevesxm is offline
Old 10-27-2006 | 09:25 PM
ls1nova's Avatar
What is involved with marinizing it besides changing the distributor, and adding closed cooling (for the alum. heads)? does it already have stainless exhaust valves?
Thanks,
Frank
ls1nova is offline
Old 10-28-2006 | 10:21 AM
jspeeddemon's Avatar
Yes it does, and the cam will work in some applications but not all, according to what type of wet exhaust, you have. It will work in all dry exhaust systems, such as Lightning, very well. Closed cooling for salt water, opinions vary for fresh water, i have had no trouble running aluminum heads, or anyone else I know in 10 years, and I have owned every major manufacturers set of heads.
jspeeddemon is offline
Old 10-28-2006 | 12:37 PM
SB
I'm definately thinking a bigger + better oil pan is needed.
Also, remember to do the bypass psi valve things to in filter pad. Many threads here on this.
SB is offline
Old 10-29-2006 | 03:35 AM
of course all.... my point simply that i was thinking when my 502 mag mpi's time out, just buying acouple of these and swapping out whats nec... just seemed a clean and simple way to go for a solid known commodity thats virtually plug and play... i mean... all new good parts , good power... how can you hate it at that price...
stevesxm is offline
handfulz28
35
08-30-2007 10:36 AM
brent05
04-23-2006 10:05 PM
brent05
0
04-16-2006 06:08 PM
migara422
19
05-26-2005 12:39 PM
migara422
9
05-17-2004 11:54 AM
