Cigarette Cafe props >
Old 10-29-2006 | 05:05 PM
Steve Snider's Avatar
Question Cigarette Cafe props
Recently upgraded 540 Bulldogs in 1994, Cig Cafe with 1.50 Bravos. Went with CMI sweepers, Dart Pro-1 aluminum heads, roller cams, and Crane ignition boxes. Running Bravo 1 four blades, 26 pitch labbed by John Janaky. Gained 500 rpm and tachs read 5500 rpm. Full fuel tanks and 5 people GPS reads 76.2 mph. One person and 3/4 tanks 78.2 mph. Will labbed 28's produce better performance or should I be happy with where I am at?
Steve Snider is offline
Old 10-29-2006 | 09:48 PM
Default Re: Cigarette Cafe props
That will depend on where your peak torque and HP are at. I would think with what you've described as far as the engines that you are about right where you should be.
WOT on the Bulldogs was 5200rpms and I would think your mods gave some more hp in the higher rpms. I don't think that you would want to spin it much less than where you are. You could be making enough torque though that you could spin a bigger prop. Only testing will tell without a dyno sheet and then testing might still be needed.
Griff is offline
Old 10-30-2006 | 11:30 AM
throttleup's Avatar
I agree with Griff. Can you give us some specifics on the motors, such as the RPM at which the peak torque and HP are produced, please. I have calculated your slip at 12% which is in the normal range. So key is hitting your peak HP at this point.
Julie
throttleup is offline
Old 10-30-2006 | 06:41 PM
The 540's were not dynoed. I guess the only true way to tell will be to try some 28 pitch props???
Old 10-31-2006 | 11:48 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Cigarette Cafe props
Depending on the recipe you have on the 26's, Labbed 28's may produce higher top end and cruise speeds. I agree with everyone else, a dyno sheet would help. The Bulldogs actually ran great all the way to 5400 rpm. This being said and knowing what those props most likely look like, I believe the 28's would help you to achieve bigger numbers.
We have test 28 box stockers to get a baseline if you wish to try them.
[email protected]
bbladesprops is offline
Smokinlegend
01-31-2026 09:16 AM
JeffC
Cigarette
12
04-03-2008 07:10 PM
4195
Prop Talk
3
05-30-2006 10:38 AM
miamioffshore
02-07-2006 09:33 AM
slumlord
Cigarette
10
05-12-2004 06:08 PM
