Stellings Box--Steering Questions >
Old 11-05-2006 | 07:19 PM
Dave1972's Avatar
Default Stellings Box--Steering Questions
Hello Everyone...I'm hoping someone can give me some information.
Does anyone have a Stellings box with a single bravo setup? If so, could you find a part number or a manufacturer of the hydraulic steering rams?
I'm working on a top-secret project with a friend and would love to have that info. If no part numbers...how about some specs for the steering rams for a Stellings box?
Thanks in advance
Dave
Update: Looks like standard issue rams work with spacer blocks to accomodate for the box. Anyone have any part numbers or manufacturer numbers on their hydraulic rams? How about specs????
Suggestions to find specs?
Thanks!!!!!!!!!!!
Dave1972 is offline
Old 11-06-2006 | 12:58 AM
articfriends's Avatar
Default Re: Stellings Box--Steering Questions
I used my std imco twin rams that were mounted on my transom by mounting imco ram ears to the box,boat had full turning radius and steering worked exactly like it did before the box,heres pics,Smitty
Attached Thumbnails Stellings Box--Steering Questions-boyne-033.jpg   Stellings Box--Steering Questions-boyne-035.jpg   Stellings Box--Steering Questions-boyne-036.jpg
articfriends is offline
Old 11-06-2006 | 01:05 AM
more,the ears are held on by 3 -1/2 inch studs,the only thing sorta cobbled is I left my original imco mounts on the transom but box didn't work well on my boat so it's coming back off and steering is going back on them. If you run them off the transom you will need serious spacers plus longer rams and you will lose some turning radius,Smitty
Attached Thumbnails Stellings Box--Steering Questions-boyne-037.jpg   Stellings Box--Steering Questions-boyne-058.jpg   Stellings Box--Steering Questions-boyne-076.jpg
Old 11-06-2006 | 01:09 AM
Heres a close up,if you buy the imco ears they have a stellings box template so you can install them in the right place too,Smitty
Attached Thumbnails Stellings Box--Steering Questions-boyne-079.jpg   Stellings Box--Steering Questions-boyne-080.jpg   Stellings Box--Steering Questions-boyne-082.jpg
Old 11-06-2006 | 06:19 AM
Fred at TRICK has some that work. I akso use the IMCO ears and rams.
cobra marty is offline
Old 11-06-2006 | 06:49 AM
I did the same as arctic!
29scarab is offline
Old 11-06-2006 | 01:19 PM
AIR TIME's Avatar
29scarab have you taken out your boat yet to see how it runs? what height is your box, how much hp do you have what speed pick did you get. I WENT WITH A 2.. SHORTIE PICKED UP 9 MPH with a carb change to 24ol, and a guy with a 25 ol used a 3'' imco ex box and picked up about 7mph. artic said he lost mph and handling
AIR TIME is offline
Old 11-06-2006 | 03:49 PM
I have it raised an inch right now. Still breaking the motor in. Only about 9 hours on engine. I haven't even had time to tinker with the prop yet.
I hope to have some more numbers in the next couple of weeks if the weather holds out.
29scarab is offline
Old 11-06-2006 | 04:18 PM
AIR TIME's Avatar
Keep Us Posted :d
AIR TIME is offline
Old 11-06-2006 | 05:48 PM
Official OSO boat whore
I used the IMCO rams and arms.
Cord is offline
fast22
1
08-20-2008 09:34 PM
alecsammy
8
08-14-2008 07:51 PM
fast22
Drives and Lower Units
5
02-20-2008 01:23 AM
Dave1972
11-05-2006 07:30 PM
z.zuperboat
2
01-10-2006 11:49 AM
