Stellings Box Help! >
Stellings Box Help!
Stellings Box Help!
Old 02-18-2008 | 06:48 PM
Default Stellings Box Help!
I have a 29' Scarab with the a 12" stelings box and a standard length bravo, the problem is the box is set a nuetral so the drive is about 1" lower than stock. My question is how do I go about raising the box? I would like to go at least 2" or 3" if its possible. Is this something I could do myself? Just hate to spend the $ on a new short lower if I don't have to.
Scott
fast22 is offline
Old 02-18-2008 | 07:09 PM
They can be adjusted to raise 2". If they are already at the highest set of holes you have two choices I get a shortie drive and/or reposition the motor. I think 6 1/2 degree is max angle.
MOBILEMERCMAN is offline
Old 02-18-2008 | 08:12 PM
Where do I do the adjusting? Is it where the box mounts to the transom? 2" would be a good enough start, then I'll go from there.
Scott
fast22 is offline
Old 02-18-2008 | 08:33 PM
Yes on the transom side of box. Look thru side plate windows to see what holes they are mounted in.
Old 02-19-2008 | 06:04 PM
Thanks for the reply.
fast22 is offline
Old 02-20-2008 | 01:23 AM
Wild Card 09's Avatar
the Flightmaster
Fast22, didnīt you just post in a previous thread that you have an Imco box?!
Anyway. What height is your drive at? Propshaft to transom parallel to each other, what is the height difference? As you have obviously established, the extension box will push the drive into deeper water. Check which postion the transom assembly is bolted to the box at, but measure the above mentioned dimension, as well.
The first step is always to get the standard drive up as high as possible, before messing with a shorty. Nosecone shaped shortíes donīt generally work at all well (they are slower) on settups that are too low in the water anyway (and at speeds below 80 mph).
Wild Card 09 is offline
fast22
1
08-20-2008 09:34 PM
alecsammy
8
08-14-2008 07:51 PM
Scarab105
23
05-10-2007 05:29 PM
z.zuperboat
2
01-10-2006 11:49 AM
JaayTeee
19
10-18-2005 04:52 PM
