35 lightening props >
35 lightening props
35 lightening props
Old 11-08-2006 | 06:51 AM
From: Ft. Lauderdale Florida & Tarpon Springs Florida
Default 35 lightening props
I have a 1995 lightening with stock 502's (415hp) am omly getting 4200 RPM WOT. I am running Bravo 28 P props. Should I go up or down in pitch to get better top end and up to the 5200 RPM that I should be getting. (Motors are new in 2003).
tanner is offline
Old 11-08-2006 | 07:55 AM
Default Re: 35 lightening props
You would need to go down in pitch. General rule of thumb is that 2" in pitch will change RPM by 200, 24's should be close. Just remember every prop is slightly different, testing is the only way to be sure. You could contact Fountain as well for info on where you could start.
RaggedEdge is offline
Old 11-08-2006 | 08:22 AM
jryan26's Avatar
Or you could buy these and keep your props!
http://www.offshoreonly.com/classifi...p?product=2575
jryan26 is offline
Old 11-08-2006 | 01:15 PM
Downtown42's Avatar
I had 25's 3 blade on my 93 35'....Just over 5000 with 502 Mag's
Downtown42 is offline
Old 11-08-2006 | 04:59 PM
35 fountain's Avatar
Tanner - you are definately overpropped. 28 bravos on a 1.50 would be fine for the HP500s but the 415s just cant turn that much rake. Ragged edge is right - the 24s should get you close - if you still need more RPM after that then get the 24s lab finished - Mercury can usually pull another 250 RPM out their props.
35 fountain is offline
Old 11-08-2006 | 06:27 PM
BZ's Avatar
BZ
Had 26 Hydro's on my 99 with 502 MPI's ran right to 5150....BZ
BZ is offline
Old 11-08-2006 | 08:04 PM
TeamSaris's Avatar
Driver-441
Racer
Labbed 26 Bravo 1s?
TeamSaris is offline
Old 11-08-2006 | 08:29 PM
ALL IN's Avatar
i have a 92 with 502's i'm running 26 hydro's at 5000rpm.i also have 24 bravo's not in the best of shape but ok and i can turn 4800.i have a max speed of 75 are you anywhere near that?73 is a everyday thing 75 low fuel and light load.my motors were freshened up last year.good luck and let us know what you come up with!!!!!!
ALL IN is offline
Old 11-09-2006 | 05:56 AM
Thanks everyone, the previous owner has a set of Bravo 25 P on the boat (dont know why he took them off) I am going to try those today. I will let you know what happens !
Thanks again
Tanner
tanner is offline
Old 11-09-2006 | 07:11 AM
Cool Re: 35 lightening props
Have 26 Hydros for my 99 with 500's that run at 5400 , also a pair of Lab 28 Bravos that run about the same. Like the Hydros better for higher speed handling, Bravos work well as all around props and cruise better.
BZ congrats on the fine shot in Powerboat. How do you like the 42 vs the 35? Pros & Cons?
