GM 502 Piston Replacement >
Old 11-17-2006 | 01:33 PM
Leathl_WS6's Avatar
Default GM 502 Piston Replacement
Where can I get a decent price on a couple of GM pistions. They seem to be on national backorder and the cheapest I found them was over $120 bucks a piece.
Leathl_WS6 is offline
Old 11-17-2006 | 01:59 PM
articfriends's Avatar
Default Re: GM 502 Piston Replacement
Buy a set of the J/E srp replacement pistons,they will fit a stock bore after honing with a tq plate (they are .004 bigger-4.470 vs 4.466),they weigh close enough to drop in without re-balancing and best of all they use regular rings,not the metric ones which will should cost you 89$ vs 200$ for the metrics. You will never have a oil consumption problem anymore either,Smitty
articfriends is offline
Old 11-17-2006 | 02:05 PM
part # 139481-498$ in comp products catalog. You can sell your remaining ones on e-bay to people like you that just need a couple,you'll have a resh bore and cheaper rings that seal better,Smitty
Old 11-17-2006 | 02:41 PM
Thats what I used!
kennyo is offline
Old 11-17-2006 | 03:24 PM
There is a set of JE forged pistons for a 502 on E-Bay now up for bid, hope this helps.
Hy-Velocity is offline
Old 11-17-2006 | 03:25 PM
Leathl_WS6's Avatar
Thanks guys Thats very helpful...
Old 11-17-2006 | 05:28 PM
t500hps's Avatar
21 and 42 footers
I just tore down 2 500EFI's....pistons look alright but bore them to 540's. I would think used 502 pistons would be pretty easy to come by.
t500hps is offline
Old 11-17-2006 | 07:40 PM
ws,
Wiseco has them and they are available individually. I bought a single one a few months ago. The only thing you have to watch is the ring size, some of the early GM's had a strange ring size if I remember correctly. I had to buy two sets of rings to get the correct combo for one engine I did about a year ago. If you can't find the part number I have it at the shop and can give it to you Monday.
Bil Koustenis
Advanced Automtive Machine
Waldorf Md
BillK is offline
Old 11-19-2006 | 01:54 PM
If you need the metric GM rings you can get them individualy from GM
HARRISONMIRAGE is offline
rslick
3
04-24-2008 01:52 PM
EYEBURN
1
07-14-2006 03:26 PM
TCH6868
6
06-16-2006 07:32 PM
homan
2
03-07-2004 09:48 PM
WILDTHING TAZ
32
01-15-2004 04:57 PM
