oil cooler recomendation >
Old 11-20-2006 | 10:20 PM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Default oil cooler recomendation
I am in the middle of a complete rebuild of a couple 502's (one at a time) and from reading many of the treads it is good insurance to replace the cooler to reduce more chances of introducing unwanted junk in the lube system.
I am considering the oem 3'x20' mercruiser cooler with ps fitting (817577t). The main reason for the oem is convenience of using old mounting, oem hoses and it is nicely tucked above the bell housing.
Is this an adaquate cooler for 500 hp n/a application?
GoCiggie31 is offline
Old 11-21-2006 | 12:59 AM
Strip Poker 388's Avatar
Rob
Default Re: oil cooler recomendation
You might try and find a take off off some 500efis'That might be easierand cheaper .Might get expensive the other way ,cooler,brackets,making up the hoses etc
Attached Thumbnails oil cooler recomendation-parts%3B-water-neck-028-medium-.jpg   oil cooler recomendation-4-1-05-026-large-small-.jpg   oil cooler recomendation-hustler-insatll-3-15-06-011-medium-.jpg
Strip Poker 388 is offline
Old 11-21-2006 | 08:10 AM
GoCiggie31's Avatar
Strip,that is a nice setup you got there-saw your build thread.
buying used I would be just as concerned as what I have now with contaminants. I have a good amount invested in this(for me), I don't want to take any chances-hence a new cooler.
The oem repl to my 3x20 cooler is $550.00; must be made of solid gold on the inside.
Old 11-21-2006 | 08:37 AM
Rob
Thanks.Yea if you could find someone you could trust on a used set up? But is it worth taking a chance breaking mid season.For me Parts failure is ok but human error is not.I think Trick and Hardin/CP perf have one like mine maybe in the 300 range?The Teaque one is 400 something.My style looks like the old Glenwood marine ones, I dont know who is making it for them.
Rob
Old 11-21-2006 | 09:46 AM
Wobble's Avatar
SORE MEMBER
Try here for some options http://www.cpperformance.com/SearchR...CategoryID=141
New cooler is smart, if you go used, you wont have any comeback on the builder (nor should you) The 620-650 should be plenty or you can go with a thermostatic one with a separate PS cooler. Get some more opinions on size. Iam on the Gulf coast so temp is a bigger issue down here
Wobble is offline
Old 11-21-2006 | 01:00 PM
Rob
http://www.cpperformance.com/detail.aspx?ID=7594
Old 11-21-2006 | 05:22 PM
Rob
Thats a pretty good price Fred
http://www.trickmarine.net/productde...id=551&incat=9
Old 11-21-2006 | 06:45 PM
I have the combo power steering / oil cooler. I used the one with threaded pipe on the water inlets for AN lines.
http://www.tpmarine.com/index.asp?Pa...TS&Category=98
jeffswav is offline
Old 11-21-2006 | 11:02 PM
Rob
EMI in the part #I guess thats Eddies marine coolers?
Old 11-22-2006 | 12:13 AM
I'd suggest getting a cooler that is a size or two to big for than you really need. And get it with a thermostat, or get one of the remote mount stats.
Kidnova is offline
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
Shore Thing
1
05-17-2006 12:11 PM
patrick22309
5
06-20-2003 05:53 PM
