plumbing fuel system >
Old 11-21-2006 | 07:42 PM
carney's Avatar
Default plumbing fuel system
Which is the proper place to feed the fuel to the pump first or the filter first. Why I ask , my fuel feed goes to the filter first then to the pump and from the pump to the carb. but I see some of the motors here on oso are to the pump first.
carney is offline
Old 11-21-2006 | 07:49 PM
Registered User
Default Re: plumbing fuel system
i have one filter before the pump and another filter after the pump
excalibur81 is offline
Old 11-21-2006 | 07:52 PM
Ted G's Avatar
Better after the pump to catch any little pieces that come off the pump diaphragm and keep them from the carb. Same holds true if it's injected-small metal particles from pump wear will booger up the injectors.
www.cbpba.com
Ted G is offline
Old 11-22-2006 | 07:53 AM
biginches's Avatar
when i first put the motor together i had the ff/water sep after the pump. i installed a inline filter after the pump
filter
and moved the ff/h2o sep. to before the pump because i wasn't confortable with the can being pressurized with 15 psi(leak would be BAD).
biginches is offline
Old 11-22-2006 | 10:33 AM
i run #10 to ramco filter then # 10 to fuel pump # 8 from pump to another filter # 8 to carb's there is no such thing as overkill
eliminatethis is offline
Old 11-22-2006 | 03:18 PM
Run A Filter In Front Of The Pump A Fuel Water Seperator Is Best. After The Pump Run A Fine Micro Filter (10) To The Engine Feed.this Keeps Water Out Of The Fuel Pump And Fines Out Of The Engine.
Jb-fse is offline
mjb
5
03-17-2006 06:08 PM
RLW
21
08-30-2005 09:27 PM
Cattitude
12
09-15-2004 11:35 PM
Pure Energy
09-27-2003 07:10 PM
fishead
1
08-21-2003 06:19 PM
