steering pulley size?? >
Old 11-26-2006 | 08:59 AM
Default steering pulley size??
Hello I need to replace the old plastic pulley the auto parts store has one for 15 bucks which is 6 5/8 inch much bigger than the orginal one merc uses I believe a 5 3/4 inch pulley .has anyone used the larger pulley or do I need the stick the the 60 dollar merc. one. Thanks
alecsammy is offline
Old 11-26-2006 | 02:36 PM
Default Re: steering pulley size??
You probably need a pulley the same size as what Merc uses. A larger one may not pump enough fluid.
Griff is offline
Old 11-26-2006 | 07:52 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I would think it 'might' be more noticeable at idle speeds only since the PS pump will be turning slower than normal. After that, should be no different than comparing cruising effort to hauling effort. The pump can only pump so much before the relief valve kicks in. Just my opinion, so......
In all honesty, only time I have ever really noticed a bit stiffer wheel, is with the add- on hyd setup at idle speeds only.
US1 Fountain is offline
Old 11-26-2006 | 09:26 PM
Big Block Billy's Avatar
Post Re: steering pulley size??
I should have a metal one. Is this serpentine ?
Easy swap. Pm Me if you want it. BBB
Big Block Billy is offline
nocigarette
Wanted
6
02-25-2008 09:06 PM
LubeJobs42
07-24-2005 08:01 PM
JMPH
2
07-18-2005 04:16 PM
timucin
10
07-05-2004 11:41 AM
p4-33
4
03-27-2004 12:28 AM
