Oil temp??? >
Oil temp???
Oil temp???
Old 11-27-2006 | 04:38 PM
Never Enuff
Default Oil temp???
What oil temp should I expect after the engine has reached normal operating temp(about 160-180)? 496 Mags in a 30OL. Ran for a few hours on Friday and the oil temp gauges never moved off 140 on either engine.
never enuff is offline
Old 11-27-2006 | 04:45 PM
Steel Outlawed's Avatar
Default Re: Oil temp???
Mine run 190. Don't be surprised if they forgot to hook them up.
Steel Outlawed is offline
Old 11-27-2006 | 05:02 PM
Never Enuff
Forgot--boy that would be a shock Thanks for the info
Old 11-27-2006 | 06:08 PM
bowtye8's Avatar
Mine are just like yours barley move off 140. I ran hard this past weekend. Well running about 4000 for about 40 miles straight. Oil temp was about 160-170 still barely off the 140 mark. I have never seen it near the 190 mark.
bowtye8 is offline
Old 11-27-2006 | 07:14 PM
customtouch's Avatar
DITTO!!!!
customtouch is offline
Old 11-27-2006 | 07:27 PM
Jay,
The 302 had HOs and the oil temp gauge rarely moved off the 140 mark. Run that new bad boy!!!!!!!!!!!!!!!!!
drdread is offline
Old 11-27-2006 | 09:51 PM
fatdaddy's Avatar
Originally Posted by customtouch
DITTO!!!!
Ditto, Ditto on my HO's.
fatdaddy is offline
Old 11-28-2006 | 08:12 AM
nomomoney's Avatar
Jay,when I had my 33 o/l with the 496's I was concerned that they did not move too.I found out that they will not move until you run it hard for quite a while in august when its pretty hot out.One thing though...the gas gauge moved very quickly...
nomomoney is offline
Old 11-28-2006 | 08:33 AM
Put a couple of Prochargers on it. That will get it off 140 degrees.
kennyo is offline
Old 11-28-2006 | 10:37 AM
Dock Holiday's Avatar
Charter Member #34
500 efi'S
190 degrees all day long before the HP upgrades
200 Degrees now
140 seems way too low to be able to boil out any water or moisture? Call Merc and ask them first hand.
Dock Holiday is offline
