Will need suggestions!! >
Old 12-03-2006 | 08:30 AM
ROADHOG's Avatar
Default Will need suggestions!!
I'm putting together a 2005 42' Executioner with Staggered 525's with Sport-Master . Ratio 1.50 What is going to be my best prop selection for all around use. Contacted Fountain and they had no suggestions, They said that they have never tested a 42 Executioner with Sport-Masters. Please RULE out HERRING'S no BUDGET for THEM!!
ROADHOG is offline
Old 12-03-2006 | 09:14 AM
wrinkleface's Avatar
Default Re: Will need suggestions!!
Ya, say Azz dragger! I say, once U find that "Ken" dude U were look'n 4! Ask him! I'm stick'n w/ Barbie myself!! George
wrinkleface is offline
Old 12-04-2006 | 07:38 AM
throttleup's Avatar
If price is an issue stock Bravo 1 props will work well for your application. The drives will have to be set at the correct height but you should be able to get good overall performance with those props.
throttleup is offline
Old 12-04-2006 | 11:34 AM
BZ's Avatar
BZ
I have major issues with slippage with stock brovo's with standad xr's I would think the Sport-Master's would make it even worse. just my .02...take a look at hydro's p-5-x's thats what I will have in the spring.....BZ
BZ is offline
Old 12-06-2006 | 06:25 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Will need suggestions!!
We can supply you with both Bravo 1 and 5 blade Maximus propellers for testing. Both these propellers can be adjusted in many ways to obtain the best performance for your boat.
Give us a call if you would like to try either or both of these propellers.
[email protected]
bbladesprops is offline
cwilks
08-24-2007 08:26 PM
Bad-Intentions
Prop Talk
3
05-18-2007 06:25 PM
offthefront
2
10-10-2006 05:15 AM
offshoredrillin
1
09-17-2006 09:03 AM
