shorty on 25 daytona. >
Old 12-03-2006 | 09:37 AM
Default shorty on 25 daytona.
I was told by eliminator that i could pick up some MPH if I installed a 2 inch shorter drive on my boat. I have a twin step with an extension box. Has anybody tried this setup ? thanks.
fbc25el is offline
Old 12-04-2006 | 05:26 PM
throttleup's Avatar
Default Re: shorty on 25 daytona.
What are your current performance numbers, WOT, prop, pitch and speed?
These number will give us a good idea of how efficient your current set up is and can make a recommendation if going higher will benefit you.
throttleup is offline
Old 12-04-2006 | 06:34 PM
81.5 gps @5100 rpm with a bravo 1 28 pitch. Thanks.
fbc25el is offline
Old 12-05-2006 | 06:55 AM
throttleup's Avatar
What motor and gear ratio do you have?
Also what speed do you see on a regular basis, a speed you attain any time you go out.
If you are running 1.5 gears now it appears going up with the drive would be a benefit. If you have 1.36 gears there would be some other considerations.
Old 12-05-2006 | 12:14 PM
I have 1.5 gears in the drive. I have a 509 chevy. in it . It needs more cam witch I plan to install this winter. Thanks for the help.
fbc25el is offline
Old 12-06-2006 | 07:57 AM
Airpacker's Avatar
Sounds like its right around hp500 numbers. Where is the top of the transom plate in relation to the rub rail? seems daytonas came in several drive height configurations. Mine is almost touching the rail. I went black hawk and picked up nearly 8 mph
Airpacker is offline
Cat-n-Around
Swap Shop
12
12-06-2008 02:53 AM
gdfatha
04-19-2003 09:28 PM
Xtremeracing
05-17-2002 09:39 PM
Bo
Eliminator
3
05-13-2002 10:52 AM
meyer
Eliminator
1
03-10-2002 01:27 PM
