Headers ?
Old 12-03-2006 | 08:16 PM
WAGS382's Avatar
Default Headers ?
Has anyone here tried the Hardin Marine typhoon headers?
I am running HP 500's that have been bumped up to 620 HP and was wondering if headers would make a noticable improvement over the Gil exhaust.
Jeff
WAGS382 is offline
Old 12-03-2006 | 08:42 PM
Default Re: Headers ?
They CMI E-tops should add 15-30 hp. If you are interested, I have two sets with tail pipes. E-mail me if you want to pursue.
BenPerfected is offline
Old 12-04-2006 | 03:41 PM
Too Old's Avatar
Jeff
I don't know anything about the Hardins.
But you may want to consider Stellings also
Too Old is offline
Old 12-04-2006 | 03:45 PM
I have done extensive dyno testing with our "B" class engines we used to race the CMI E tops are worth every bit of 25-30 HP.
mrhorsepower1 is offline
Old 12-04-2006 | 05:27 PM
Ateco's Avatar
Etops will provide more power and of course that nice bling factor.
Fred is not kidding, there will be a 10% price increase.
Good luck with your project.
Kirk
Ateco Engine and Dyno Shop
Ateco is offline
Old 12-04-2006 | 06:46 PM
bob
Charter Member #40
Anybody ever do any comparisons with the "tube tops"? They look to have runners at least close to 32-34" in length and close to being equal length.
bob is offline
Old 12-04-2006 | 08:27 PM
WAGS382's Avatar
mrhorsepower1
Thanks for the response
These are 502's with the AFR 305's heads and a mild cam. All the parts are original HP500 except the heads and valve train and I like the stock look of the gil's.
The boat is a 382 Fastech, it responded well to the extra 100 hp per side with a 8 mph increase, I am not sure what 25-30 more would do.
Has anyone compared the E Tops vs sport tubes?
WAGS382 is offline
Old 12-04-2006 | 08:53 PM
I have done back to back comparisons on the CMI E-tops vs. the Sport Tubes. The Sport Tubes make 15-20 HP more, but only above the 5200-5400 RPM range. There are points from 4000-5000 RPM where the E-tops make more torque than the SP's. The Sport Tubes start to shine from 5300-6800 RPM. On my combination, the 2 1/4" ID Big Tubes added another 20 HP over the SP's but again only at the higher RPM.
The E-Tops are the all around best value...except for the bling!
Old 12-04-2006 | 10:19 PM
axapowell's Avatar
Where To
I had heard that there were ALOT of problems with the "Big Tubes" cracking around the mounting flange on the heads? Worth the extra 10-15 at that RPM?
I also noticed an increase of 30-40 hp from the Gils to the E-tops!
Dave
axapowell is offline
Old 12-06-2006 | 02:14 AM
Donzi502's Avatar
E Tops rock!
Donzi502 is offline
