Stereo - wiring for 6 speakers? >
Old 12-03-2006 | 10:28 PM
Wooderson's Avatar
Default Stereo - wiring for 6 speakers?
One of my winter projects is to put an updated stereo in the family bow rider. It currently only has a pair of speakers in the back. I’d like to add two more pairs, one beside the driver/passenger, and one up in the bow area.
What is a preferred/acceptable method of wiring up 3 pairs of speakers to a head unit assuming no additional amps? Is it OK to wire 2 pair of speakers in parallel on the rear channel, and put the remaining pair on the front channel? The rear channel speakers would then present a 2 ohm load to the receiver and the fronts would present a 4 ohm load. Is that OK? The head unit is a DEH-4800MP
I’m assuming it would be best to run separate amps on the front and rear channels. I’ll probably go that route eventually as the head unit has 3 sets of pre-outs (front/rear/sub), but would at least like to try it without external amps first.
Wooderson is offline
Old 12-04-2006 | 12:18 AM
BY U BOY's Avatar
Default Re: Stereo - wiring for 6 speakers?
At 2 Ohm The Head Unit Amp Wiil Not Last Long.
BY U BOY is offline
Old 12-04-2006 | 01:06 AM
I would run a 4 channel amp about 40 rms watts x 4 for 4 speakers and run 2 speakers off the head unit. You should be able to get a decent amp for $150.
Griff is offline
Old 12-04-2006 | 09:05 AM
UNSANE's Avatar
Use external amps. The HU won't like it and will shut down by at a certain volume level (which won't be much) to protect itself. Even a cheap seperate amp will sound better than the HU's amps.
UNSANE is offline
Old 12-04-2006 | 11:11 AM
Wooderson's Avatar
Thanks guys, that's what I needed to know!
Clay Washington
Cigarette
3
08-31-2011 11:13 AM
hp500efi
6
04-30-2007 10:47 PM
InXS
Cigarette
4
06-14-2006 07:49 AM
onesickpantera
01-15-2006 12:23 AM
26scarab
02-22-2002 11:05 AM
