7.3 powerstroke engine codes
Old 12-09-2006 | 12:10 AM
berns29scarab's Avatar
Default 7.3 powerstroke engine codes
have a 99 f-250 powerstroke (8/98 build date) with a 4" exhaust from turbo back, edge evolution programer and air raid intake...when i run level 3 (100hp) i get these codes in my puter...P0238 Turbo boost Sensor A Circut High Output, P1249 Wastegate fail Steady State Test, P1211 Inj Control Pressure Above/Below desired level, and a P0603 PCM processor keep alive memory error (KAM)...is this normal or do i have an issue ?
berns29scarab is offline
Old 12-11-2006 | 05:58 PM
Default Re: 7.3 powerstroke engine codes
ttt
Old 12-12-2006 | 09:13 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you stomp on it, it will produce an overboost code to make you CEL briefly flicker. This is probably the code you are seeing.
Sydwayz is offline
arrover
4
06-29-2008 09:41 PM
arrover
7
05-09-2008 09:30 AM
PremierPOWER
6
06-20-2007 11:39 PM
scooby94
13
07-24-2006 11:21 AM
Hot Boat
07-28-2003 07:31 AM
