Gen 6 guys...roller lifters >
Old 12-19-2006 | 09:32 PM
Default Gen 6 guys...roller lifters
I have a 454HO that I'm looking to replace the cam for one w/more lift - like in the .600 range. I heard that factory lifters can't go more than .575. But some guys say they are using the oe lifters w/.600 cams.
Any input is appreciated - thanks!
Vince
69-CHVL is offline
Old 12-19-2006 | 09:53 PM
racinfever's Avatar
Default Re: Gen 6 guys...roller lifters
Depends on the base circle diameter of the cam shaft your using. Most small crane cams work fine with factory lifters up to .610 lift.
racinfever is offline
Old 12-19-2006 | 10:05 PM
Donman's Avatar
I ran factory OEM roller lifters in my Gen 6 engine with a Crane 587 / 612 cam. I later swapped that cam for a custom roller 629 / 629. These same lifters have over 300 hours on them.
Donman is offline
Old 12-19-2006 | 10:54 PM
I have to admit, this for a 69 chevlle
I'm upgrading heads to the GMPP alum rovals w/2.25/1.88, so I'd like to get some lift.
Seems to be alot more experience w/the Gen 6 motors over hear.
I'm thinking either the:
Comp XM 284 230/236 112 .547/.547
Crane 168731 226/236 .587/.610
Voodoo 231/239 .6/.6
I like the XM284, but I think I'd be doing myself a disservice w/the low lift. Guys here seem to like the Crane. I wanna use the OE lifters b/c there almost new, and these motors already suffer from heavy valvetrains, and the Crane lifters are even heavier than the OE lifter. And for some reason I just trust OE stuff. Not to mention $400.00+.
There seems to be debate on the lifters. Either they:
Fall below the dog bone,
push the dogbone up,
oil holes dont line up.
Here's a pic of the oil hole height between the oe and crane lifters:
here's how low the lifters fall into the block with a .600 voodoo:
69-CHVL is offline
Old 12-20-2006 | 06:13 PM
Donzi502's Avatar
I have a 230@ 50 & 600 thou with a custom grinde Com cam and stock 230 hour roller lifters. Runs strong but some bottem end torque has gone away and after a real good tuning session not much better top speed. Next time i would run 550 and 225 @ 50 and have the bottem back a little. Jas
Donzi502 is offline
Old 12-20-2006 | 06:36 PM
Jas, how was the lifter engagement w/the oe lifters?
69-CHVL is offline
88Fount33
Do It Yourself, Boating on a Budget
9
10-09-2008 06:38 AM
TROUBLE MAKER
0
12-25-2005 08:13 PM
KCHOTBOAT
45
08-26-2005 10:48 AM
ASD-6
4
01-10-2003 03:20 PM
Bo Knows
04-02-2002 09:20 AM
