Mass Flo efi system >
Mass Flo efi system
Mass Flo efi system
Old 12-29-2006 | 10:07 PM
Default Mass Flo efi system
Does anyone know anything about this efi system? www.massfloefi.com Sounds cool but I want to check around before I drop 3K.Thanks,BOB
Bob280Silencer is offline
Old 12-29-2006 | 11:01 PM
Elite Marine's Avatar
Default Re: Mass Flo efi system
Look into Autronic. Seems to be a very nice set up also.
http://www.autronic.com/
Elite Marine is offline
Old 12-30-2006 | 05:57 AM
They use a mass air flow sensor and not speed density system. ?is it marine durable? The sensor is how it can self tune.
cobra marty is offline
Old 12-30-2006 | 12:21 PM
Marty, www.massfloefi.com They use a air flow meter from a LS-6 chevy inside the air filter on top of a 1000cfm throttle body. BOB
Old 12-30-2006 | 02:51 PM
articfriends's Avatar
I read all thru their site last night,it seems they are using a 302 ford ecu,I couldn't figure what they are doing for a timing curve/timing map though. It seems like a good idea,a person could almost duplicate what they have done for less than 1/2 if you were ambitious,Smitty
articfriends is offline
Old 12-30-2006 | 03:48 PM
Smitty,The only info they need is approx hp.(for injector sizing)When the system is installed,you need only set the timing and fuel pressure.(49 lbs)They will probably do a custom curve depending on the application? BOB
Old 12-30-2006 | 04:01 PM
Smitty,That's 40 lbs fuel pressure. BOB
Old 12-31-2006 | 11:53 AM
ttt ?
Hardin Marine
New Products and Member Discounts
3
12-13-2007 11:05 AM
Rrice
10
06-06-2007 08:06 AM
dean51267
4
07-17-2005 08:19 PM
tomcat
7
05-31-2004 09:06 AM
rjcardinal
9
03-14-2002 11:09 AM
