single v bottom with #6
Old 01-01-2007 | 04:06 PM
Default single v bottom with #6
What is the smallest single engine v bottom you have seen with a #6 on the back? 27? 28? 30?
It seems that there are quite a few after 32 feet.
tomcei is offline
Old 01-01-2007 | 04:08 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: single v bottom with #6
I have seen two #6s on a 29 Scarab.
TeamSaris is offline
Old 01-01-2007 | 04:16 PM
Coolerman's Avatar
PF Marine
There is a guy on this board with a 30' checkmate I believe, has a turbo motor in it and runs 115mph+ with it.
Coolerman is offline
Old 01-01-2007 | 04:24 PM
TeamSaris's Avatar
Driver-441
Racer
What size Activator is Masher44's? I think that has a 6
Old 01-01-2007 | 04:29 PM
TUFFboat's Avatar
I would be very interested in hearing how a small boat handled with a #6 compared to a bravo style out drive.
I have heard of a few guys going with BIG hp 1000-1100hp on small light boats (single vee) but I can't figure out how you would make it last without the big drive on it. The big #6 weighs like 500lbs and consumes hp just to run it.
So, has anyone got this handled?
TUFFboat is offline
Old 01-01-2007 | 04:32 PM
TeamSaris's Avatar
Driver-441
Racer
I would run a Konrad before a 6 if possible. Konrad said if they were not being conservative they would rate it at 1000HP.
Old 01-01-2007 | 04:39 PM
JCPERF's Avatar
My boat and Masher's have #6s on the back.The problem isnt so much the HP drain, its the CG of the boat.When you go from the Bravo to the #6 it adds 320 lbs. to the back of the boat.The center of gravity now is much further back than with the Bravo.The handling characteristics might be jeopardized.
Attached Thumbnails single v bottom with #6-4064_17.jpg   single v bottom with #6-sharkey2.jpg
JCPERF is offline
Old 01-01-2007 | 04:40 PM
there arn't many used Konrads to pick up but there are a few #6
I'm mostly concerned with the weight and how it would effect a single boat around 27-30 weight approx 5800lbs formaly a bravo
tomcei is offline
Old 01-01-2007 | 04:42 PM
It would then seem best to move the engine foward wouldn't it?
tomcei is offline
Old 01-01-2007 | 04:44 PM
McGary911's Avatar
Wasn't there a guy at one of the radar runs a year or 2 back with a 25' Baja with 1000+ and a 6? I'll see if I can find the thread.....
McGary911 is offline
