single v bottom with #6
#101
Can we re hash this thread 10 years later !? I have a Warlock 29' World Class 1994 with a straight bottom. I've broke my bravo's too many times to count . Got a hook up for a #3A and a spare . Really leaning to go this route. Not interested in Nay sayers. I've seen plenty of surface drives , arneson , #6 , and #4 on boats that work great . Clearly it's in getting the drive height and prop correct . How has had success !? What prop shaft height did you run? What prop did you run?
if you're still planing on racing the boat. (Procharger guys right?) I would also go straight to a crash box. It'll help recoup some of the parasitic loss in the drive. I went the transmission route at first and saw solid gains everywhere by eliminating that.
As far as props my boat planes with pretty much any of them. I would be willing to let you try some that I have in various diameters and pitch assuming you are running a RH drive. I have the some of the smallest pitch big shaft props.
#102
there are many ski race boats here in Australia with #6 behind 1350s, 1650s and custom built turbo motors. Most run a 2 speed powerglide transmission to get some low down launch and then shift gears for high speed
#103
I was just at the Catalina Ski Race and saw a 21' hull with a Merc 1550 and a PAIR of #6 drives on the back
Check out Aussie ski racing. They run 21' hulls with #6 drives to 120mph sustained down the river while pulling a pair of skiers.
I'll try and post some pics when I get back
#104
speaking from first hand experience drive height is absolutely critical to get it to perform, too low and it's going to be a dog. Period. Dragging that giant case through the water is like dragging a boat anchor. I've been there done that and wasted more money then I'd like to talk about. On the transom even with the bottom. If it's on a box I'd set the box so you can go even 1 and 2 above. I've ran my 28 2 below 1below even and 1 above. night and day difference in speed and boat attitude all around. The higher it went the better the boat felt and handled and drastically started to go faster. Planing ability never changed much. 1 above slips a hair more getting up but even in Point pleasant testing Saturday it planed in 4-6s. If I wasn't racing it I think I would fill the transom and try even higher but I feel I'm at the point of diminishing returns.
Any ideas on how this might work with a #6 prop? Could I still get bow lift/ trim reaction? Would this be too deep for the scx-4 case and or a #6 prop? I was told planning would be my issue with the scx @ 2-1/4” below but I could jump outta the hole if I wanted to.
#105
Dragging the boat anchor, that’s exactly how my 25 outlaw felt with an imco SCX 2-1/4” below on a 12” ext box. Whippled 509 just didn’t really feel like it had nearly double the 496ho hp that it replaced. So now it looks like Scx-4 is my only option to go higher without transom work. Scx-4 would put me at 1/4” below, on a 12 ext box.
#106
Unless Konrad has figured out how to make their drives live I’d stay away from them in high hp applications. I installed a pair of konrads in a center console with twin 480 ta mars and they wouldn’t stay together. If they can’t handle that application there is no way the will live in a high perf application with 1000 hp
if I am not mistaken there are some number 6 drives on some
of the Australian ski race boats. I thing those are under 25’
#107
#108
I’ve talked with Pro27 a few times and he has been helpful and given me some pointers. Most that I’ve talked to about insist that I should step up to the #6 props otherwise gains could be minimal.
Where are the Australian ski racer x-dimensions or prop shaft in relation to the bottom of there hulls?
#109
Have you ran your 28 with a #6?
Was it a non stepped or stepped hull? With notch?
#110
My boat has a #5 on an 18” box non stepped no notch. Race layup but not really light by any stretch just no cabin or liner. Never ran any other drive on it nor driven or ridden in one with a bravo to compare. Been in plenty of single engine bravo boats including Afew 24 panteras just not a 28.
