Need some help.
Well I tryed to start the New Year off right and put the boat in the water today. I fired it up and one of my motors was not blowing water out the mufflers. I no it can't be hard but I have never changed what ever I need to change to suck up water. Any advice would be much appreciated.
Well that would be your impeller. I am by no means an expert. I have older 454's the impeller is located below the motor on the left side.
It's not a technical hard job, but getting the thing out can be some work.
Your freshwater pump pulls from the water pick-ups on the drive the impeller is in the freshwater pump (located on lower left of engine the pump is driven by your serpentine belt). You might as well do both engines while its being done. I think the kit is around $75 bucks.
You have HP500's, right ?
Here's a breakdown of it:
http://www.mercruiserparts.com/Show_...+PUMP+ASSEMBLY
It is located on the lower starboard side of each engine.
Don't forget to backflush the coolers while you have
the pump off.
the pump off.
Thank you guys for the help. I just took a look at it and it looks pretty simple. I didn't know what I was supposed to be looking at, thats pretty funny. First I'll be changing impellers and next adding blowers it's all the same!! Thanks again.
