500hp carb to 525 EFI?? >
Old 01-03-2007 | 11:39 AM
rslick's Avatar
Default 500hp carb to 525 EFI??
I have a 99 500hp carb engine and would like to convert it to EFI with better aluminum heads and a cam change. Is it possible to use a 2003 525 intake, ecm, coils, ect to convert my engine? Is this ECM reprogamable and will it work with my analog gauges? Would it be better to use a 500 EFI intake and ECM?
Would the EFI convert be worth it or should I stay with a carb?
Thanks in advance.
rslick is offline
Old 01-03-2007 | 12:29 PM
jdnca1's Avatar
Default Re: 500hp carb to 525 EFI??
I think you would find a 500EFI conversion way, way, easier....from what I've heard the 525's a a real bear to mess with. Not to mention closed cooling on them.
jdnca1 is offline
Old 01-03-2007 | 06:38 PM
H2Xmark's Avatar
the 500efi would be the way to go, Arizona speed and marine makes most of the parts for the update, also look into the mono blade throttle body and ecm reprogram with the cam and heads will give you a big increase in power
H2Xmark is offline
Old 01-03-2007 | 07:35 PM
are all 525 closed cooling
JMPH is offline
Old 01-03-2007 | 08:47 PM
All the EFI 525 are close cooled, the older 525 sc were not. Steve
509 SC is offline
Old 01-03-2007 | 10:27 PM
rslick's Avatar
Thanks for all the info. I kind of figured the 525 would be a headache. The 500 EFI conversion sounds like a better way to go. My last two boats were injected and I liked it other than doing any modifications. A carb would make modifications easier but it has been so long since I have had a carb engine I am not sure I will like it. I will be making the transaction on the new boat soon and will run it as is for awhile, then decide if EFI is what I want to do.
Thanks,
rslick is offline
Old 01-28-2007 | 09:58 PM
khadley's Avatar
you don't have to have closed cooling for the 525 systems to work. and if you put the crane 741 cam with aluminum heads everything would be the same as a 525 just no closed cooling.
khadley is offline
Old 01-28-2007 | 10:14 PM
THEJOKER's Avatar
Contact Tyler Crockett , he just did a bunch of r/d work on what you're looking for. 810-531-1809
THEJOKER is offline
Old 01-28-2007 | 11:12 PM
Thumbs up Re: 500hp carb to 525 EFI??
Thanks in advance.
Are you located in Spokane, Wa. If so check out the Seattle boat show and look up www.mercermarine.com (high performance) they seem extremely knowledgable with merc racing product and more. Looks like they even had some heads and intakes at the show to choose from.. Thanks, Cam-shaft.
Cam-shaft is offline
Old 02-04-2007 | 07:06 AM
Jmemoli's Avatar
Goumada P5-38
Keep the iron heads you have and send them to Jim Valako -
He has some trick mods and will have you cranking out more power than a Merc 525 .
He is in Grand Rapids, Mi. -
Jmemoli is offline
Elite Marine
20
09-12-2008 05:28 PM
bcarpman
37
08-24-2006 03:07 PM
StarLoone
3
09-21-2004 04:57 PM
Dave M
8
08-31-2004 08:02 AM
ISurvivedNMU
0
04-08-2004 08:23 AM
