Switchin corsa quick and quiet to captains call >
Old 01-05-2007 | 06:00 PM
Default Switchin corsa quick and quiet to captains call
Im thinking of switching from corsa quick and quiet 2 to the captains call. I want to be able to switch it. I was wondering if I need to order the whole kit or just the diverters. Also do you think it will be a tough job?
Thanks guys
pol98xc6 is offline
Old 01-06-2007 | 01:06 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Default Re: Switchin corsa quick and quiet to captains call
I can get you the kits. We are a Corsa distributor. It's not a tough job to swap it over from what you have. The diverters will need to be replaced to the electric ones with the wire harness and a switch.. Call me if you need them.. Jamie / Lakeside 570-639-2628
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 01-06-2007 | 06:35 AM
Im going to need a set of exhaust tips too. Louder the better!
pol98xc6 is offline
Old 01-06-2007 | 08:05 AM
Feel free to give me a shout.. I have those to in several different varieties.. Jamie / Lakeside 570-639-2628
Old 01-06-2007 | 08:09 AM
itilldo's Avatar
if you don't mind but what is the difference between the two systems?
itilldo is offline
Old 01-06-2007 | 08:17 AM
One exhaust is thru hul thru prop all of the time (Q&Q 2)... The other one allows you to switch between thru hull thru prop.. Jamie / Lakeside
Old 01-06-2007 | 08:23 AM
Thanks I will definetly give you a call around the end of the month!
pol98xc6 is offline
Old 01-06-2007 | 08:39 AM
Sounds good.. talk to ya then.. Jamie
Old 01-06-2007 | 04:44 PM
whats the diference between the captains call and the quick and quiet plus?
pol98xc6 is offline
Old 01-06-2007 | 05:13 PM
Captains call is a non muffled switchable system.
Quick & quiet 2 is a non switchable thru hull & prop system with mufffled tips.
Quick & quiet +is a switchable thru hull & prop system with mufffled tips.
Jamie / Lakeside
