93 chevy diesel 6.5 problems please help!!!!!!!!!!!!!!!!!!! >
Old 01-08-2007 | 11:25 PM
Default 93 chevy diesel 6.5 problems please help!!!!!!!!!!!!!!!!!!!
i have a 93 chevy diesel truck it smokes white when in idle it also has blowby and missing, has 190000 on it ,the glow plugs have been chenge to manuel, but when you get on the highway it uns good ???????.
erasmozamora is offline
Old 01-09-2007 | 01:07 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: 93 chevy diesel 6.5 problems please help!!!!!!!!!!!!!!!!!!!
This site is much better suited for your questions:
http://www.dieselplace.com/forum/index.php
Sydwayz is offline
Old 01-09-2007 | 03:36 PM
Sounds like a head gasket.
Wannabe
wannabe is offline
Old 01-09-2007 | 08:57 PM
fountain1fan's Avatar
e mm i've got a friend that is a desel mec and has one of them. i'll ask him tomarrow and let you know what he said .
fountain1fan is offline
Old 01-13-2007 | 01:13 PM
bob
Charter Member #40
had alot of problems with the heads cracking between the valves.
bob is offline
Old 01-14-2007 | 02:22 PM
Cracked head....
Those are called "killerdiesels" over here....
MikeyFIN is offline
Old 01-14-2007 | 03:28 PM
Have a 95 just had cracked heads. I went with aftermarket heads that are thicker. You have some things you need to check first. Do a Pressure check on the cooling system. Engine running and engine off. You could have a turbo going bad also but doubt ful since it clears up at speed. Sounds More like you may have a Problem with your fuel system. Aleaking injector or a bad fuel Pump. Will white smoke with a head/headgasket failure or way to much fuel. Since it does clear up and you didnt say it overheats or pushes water out of radiator i would be more inclined to think you have a bad injector. With that much mileage i would Redo the injection pump and injectors if you find a bad injector.
superwrench0166 is offline
Old 01-14-2007 | 04:15 PM
oreo11zeus's Avatar
Default 454 needed for my Dually !!!!!!
Looking for a rebuildable 454 with all the alt/water, A/c carb etc. Anyone?
oreo11zeus is offline
BowenCT
12
10-25-2008 04:44 PM
Sunsation 32
08-06-2006 03:32 AM
MIAMIBOYZ
3
06-01-2006 06:36 PM
Boomer35
17
09-29-2005 12:12 AM
sonicator
41
06-27-2005 09:38 PM
