Help!!!! Water in Trim tab Piston
I Just got my T-Bred with i believe K-planes but not sure if they are but they are over sized and beefed up. Point is there not stock and i have water in the piston. Also the piston if i push on it feel spongy, as if there was air in it like a coushin. I put the tab down or tried to only went 3/4 of the wat sounded like there wasnt enough fluid. anyway if there wasnt no big deal but as i left the tab down water came out of the lower seal, not the piston center seal the large one at the bottom. OK, Now can i have that rebuild new seals or do i need a new piston and where can i get it if so
If it is a Merc one you can still get the seals/scrapers.
If it is Bennett then you can get those as well. Any chance you can get a picture?
Put your best foot forward!
not that mercury isnt, but with merc parts for merc stuff, except for the chance of saving $, on a not so isolated piece or part, its a garanteed solution.
