Paint Remmoval
Old 01-22-2007 | 10:18 PM
Sick Stinger's Avatar
Brotherhood #1
Default Paint Remmoval
Looking to remove paint from my swim platform. Its a bar styleplatfor like seen on a powerplay or as in my case a Thoroughbred. I want to repaint it because of the chipping and peeling of it. I beleive its stainless if im correct
Sick Stinger is offline
Old 01-23-2007 | 12:29 PM
Default Re: Paint Remmoval
Its aluminum and the best way to refinish it is to have it sand blasted and powdercoated.
Griff is offline
Old 01-23-2007 | 09:11 PM
Brotherhood #1
Hey griff i just took it off and took some paint off it is SS but i would assume the same physics and system would apply to cleaning and painting am i correct??
Old 01-23-2007 | 09:20 PM
I paint, and you are correct! if it's a peeling problem then it needs to be blasted! but if it's just chips from use then it can be featheredged and painted over with no problem............
SUNSATION 25 is offline
Old 01-25-2007 | 05:16 PM
Brotherhood #1
no it need to be taken down to bare steel then re shot do i have to power coat or can i prime and paint
Old 01-25-2007 | 05:32 PM
BY U BOY's Avatar
have it powder coated it will look much better and last longer.
BY U BOY is offline
Old 01-25-2007 | 06:08 PM
cuda's Avatar
I have to disagree. When the pc starts to chip, and it will, it comes off in big flakes.
cuda is offline
Old 01-25-2007 | 06:24 PM
If it's a peeling (adhesion) problem then it needs to be stripped, if it's just chips from use it can be featheredged and primed then refinished. And I agree with Cuda, have it painted rather than powdercoated..........
Old 01-25-2007 | 09:08 PM
I used paint stripper from lowes and had mine powdercoated again. The stripper made it easy to get off.
Monza SS 24 is offline
Old 01-25-2007 | 09:41 PM
Brotherhood #1
The chips are huge nothing that a blend or feather edge will help i have a bady guy that does all custome stuff (if anyone need it also) to take care of it i just have to prep it but i want to be part of the project so that we can do a little customeizing with paint=-)
SLINGSHOT
Detailing, Painting, & Fiberglass
8
09-06-2011 08:10 AM
masher44
Activator
49
05-15-2008 10:35 PM
thedonz
19
09-20-2006 05:37 PM
wwwTOPDJcom
2
03-06-2003 10:36 AM
