Question about new bearings >
Old 02-01-2007 | 12:12 PM
Rookie's Avatar
Default Question about new bearings
Question:
If you have a good engine that has no ticks, knocks, holds 40lbs oil pressure at idle when first started, 15 lbs after a hard run. Is it ok to replace the old bearings with new bearings and not have the crank polished or ground, when you have it pulled to replace gaskets due to oil leaks??
just curious
Rookie is offline
Old 02-01-2007 | 12:35 PM
Registered User
Default Re: Question about new bearings
If the crank measures within spec, and has no damage to it, you don't have to touch it. Measure, get your clearance right, and put it together.
the duke is offline
Old 02-01-2007 | 12:57 PM
Pat McPherson's Avatar
My 502 did exactly what you are describing at about 500hours. I freshened it with new rings, bearings, oil pump, and did a valve job.
She has been running great with another 140hours so far.
Make sure that you also replace the cam bearings.
Patrick
Pat McPherson is offline
nordic95
5
01-27-2006 08:36 PM
Barrett
09-04-2003 06:48 PM
SSComp
2
05-12-2003 10:48 AM
Elite Marine
2
09-20-2002 08:45 PM
boot
07-16-2002 12:15 AM
