Fuel pump mounted on seawater pump - leaking solutions??? >
Old 02-03-2007 | 06:39 AM
BillR's Avatar
OSO Moderator
Default Fuel pump mounted on seawater pump - leaking solutions???
I have the latest version of the mechanical fuel pump that is mounted on the seawater pump.
I took it off last night and was surprised (again) to find fuel mixed in with the oil. This latest version was supposed to remedy that - guess not.
Has anyone figured out a way to keep the fuel out of the oil?
Can you buy just the lower base section or re-place the rubber diaphram on the base???
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 02-04-2007 | 03:57 PM
Default Re: Fuel pump mounted on seawater pump - leaking solutions???
so now for the real question.... why not just install a holley blue or red pump or other 90-100 gph electric pump the mechanicals driven that hard (fast RPM) fail more often with respect to the diaphram and related components than their cam driven counterparts. Electrics with a ignition circut mounted relay controlled power circut is much more reliable and easier to operate, also allows for turn key starts even if the hull sits over a winter or other season of non useage for what ever reason
npartin is offline
Old 02-05-2007 | 06:20 PM
Do you need to install any additional regulator with these Holley pumps or is it a direct replace for the pulley pump?
Pismo10 is offline
Old 02-06-2007 | 01:38 PM
Nordicflame's Avatar
Pismo,
A Holley HLY-12-454-13 diaphram assembly screws right on to the armature assembly of the Merc pump.
Dave
Nordicflame is offline
Old 02-06-2007 | 03:23 PM
BillR's Avatar
OSO Moderator
I am upgrading to the Keith Eikert pumps that are a direct bolt on. However the diaphram in the Merc base still lets fuel into the oil reservoir of the seawater pump.
How to stop that?
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
BillR
11
07-29-2022 06:31 AM
BillR
27
08-10-2008 11:31 PM
jdub
7
03-26-2007 05:06 PM
BillR
2
02-01-2007 08:54 PM
Cignificant
8
07-09-2003 06:21 PM
