Ignition systems >
Ignition systems
Ignition systems
Old 02-05-2007 | 12:36 PM
Default Ignition systems
What ignition systems do you run on your boat? I have thunderbolt 4 on a pair of carbed blower motors. And my mechanic wants to switch to msd. But i have heard problems with msd boxes going bad and burning up coils. So what do you guys think?
BobbyB is offline
Old 02-05-2007 | 03:00 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Ignition systems
As with any electorinc parts, there are problmes that can occur. I have a complete MSD set-up on my NA 540 for 2 seasons without any problems.
Vinny P is offline
Old 02-05-2007 | 03:34 PM
I switched to a complete msd system 5 years ago on my blown 509 no problems.
2fastfountain is offline
Old 02-05-2007 | 03:38 PM
Keep your Merc distributor and go with the Crane system has all the advance curves for Merc blower motors built in and have never heard of a failure yet do a search on this site about them. MY 2 CENTS
brian41 is offline
Old 02-05-2007 | 03:42 PM
Hi,
i had a Jakobs Elektronics Fire Control 4000 on an 454 / 330 Hp, ( before i changed to 502EFI) I was surprised that after installing this system the running quality was changed 180° than before. No starting problems, no more black Sparkplugs after long idling,a little more Topspeed, better throttle response and absolutly clean idle. This is realy a good ignition system i woul buy it again
Greatings from Germany
Hans
Scarab28Germany is offline
Old 02-05-2007 | 03:43 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
I agree.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 02-05-2007 | 03:55 PM
Wally's Avatar
Were doomed!
I ran two MSD systems in my Scarab for 3 yrs.......burn one ign box up....couldnt tell me why but they fixed it and i was back on the water inside a week.....the only thing i can complain about on the MSD's was the rust! There was no realy way to keep it out.....and MSD knows about it too....
-Wally
Wally is offline
Old 02-05-2007 | 05:03 PM
I would go Crane also....
cstraub is offline
Old 02-05-2007 | 05:52 PM
Thunderstruck's Avatar
I put Crane boxes, HI-6M with stock 500hp (Thunderbolt IV?) distributors. I mounted them (as instructed, not on the motor) on the "firewall" and no problems for 2 years. The Cranes have built in adjustable rev limiter and 6 or 7 different ignition curves including locked out timing for blower motors.
You do have to drill the distributor rotor plate with the provided template to shift the rotor 30 degrees which can be tedious if you are not a machinist and the boxes need to be wired directly to the battery or battery switch.
I tried but could not get any consensus on running the stock 500 hp knock module with the ignition retard on the Crane box. Crane specifies another brand of knock module.
Look on the Crane website and find the installation instructions.
Thunderstruck is offline
Old 02-05-2007 | 07:34 PM
How about the DUI system?
jdub is offline
