Installing exh.manifold&Risers backwards >
Old 02-10-2007 | 09:10 AM
Default Installing exh.manifold&Risers backwards
Hello,im in the process of mounting a 496 in my deep V fishing boat in disguise.What do you think of this,i have:
Crusader FWC setup
VolVo SP(same as duoprop with one prop)
3'' thru hull exh(should i go to 4''??)
I think i want to use the crusader manifolds ,they have a nice smooth transition to the riser and it dumps the water in farther downstream in the exhaust.Could i mount these on backwards so i can get some space to mount mufflers under the engine or on the sides of the engine also,would it be ok if the exhaust has a slight uphill climb to the stern.Like most others building a 496 im wondering about camshaft selection-flat tappet hydraulic,i am installing a camshaft oiler/shower in the valley to eleminate the problem the BB has of killing new cams.-thanks,Don
71' Chris Craft Lancer 23
CCLancer23 is offline
Old 02-10-2007 | 09:16 AM
monstaaa's Avatar
i believe the bolt patern is the same left or right. so it shoold work. as for the incline in the exhaust , i would say no. you ll increase your chance of reversion.
monstaaa is offline
Old 02-10-2007 | 09:22 AM
Yes you can mount them backwards. Just check out any V drive boat.
As for the incline, that will depend on the riser setup you use.
Gary
rdoactive is offline
Old 02-12-2007 | 02:12 PM
thanks for the info guys looks like it will work-Don
dumbguy123
Swap Shop
9
11-03-2008 01:56 PM
Rage
41
02-18-2007 09:42 PM
davids94
05-25-2005 11:41 AM
PhantomChaos
01-27-2004 09:37 PM
mxz800
03-28-2003 08:03 AM
