crack in repaired area
boat was involved in accident large hole , said was told was repairable , 5months later the repaired area now has a crack separating new repair and the existing , seems like area is all joined but cant reall tell , took back to glass man , just wodering if this will be an ongoing prob looks also as if used some type of filler as a final coat can scratch with knife quite easily any help thanks rob
i had given up on this thread . what causes a crack to come after a repaired area , couldnt handle the cold crfack is a about one 8th inch going up entire side of patched area seems firm just cracked thanks rob
hey kirk how goes it , chopin at the bit to get that hot rod done and on the water , me too then i notice a crack that had been fixed this earlier this year thanks and nice talking to you rob
What happened Rob? any luck with your end of that project?
