How many times do you Torque new Rod Bolts? >
Old 03-04-2007 | 04:45 PM
Default How many times do you Torque new Rod Bolts?
I have been doing it twice on new bolts. I would have to assume the machine shop does this also when they put in the bolts and resize the rods.
I have been doing it the same way for 25 years and just curious what everyone else is doing.
1BIGJIM is offline
Old 03-04-2007 | 04:56 PM
cariveau's Avatar
I don't think you need to do it twice if you are using high quality ARP or better rod bolts.
cariveau is offline
Old 03-04-2007 | 08:54 PM
Jim,
ARP recommends torqueing them 3 times. Supposed to "equalize" the friction so you get a more accurate clamping force when using a torque wrench. I usually do them at least twice. I would think that if you are using a rod bolt stretch gauge to tighten them it would not matter how many times.
Bill Koustenis
BillK is offline
Old 03-05-2007 | 07:08 AM
cariveau's Avatar
I thought you should always use a stretch guage.
cariveau is offline
Old 03-05-2007 | 08:36 AM
Thanks for the replys.
1BIGJIM is offline
Old 03-06-2007 | 06:53 PM
Crazyhorse's Avatar
Ideally a stretch gage should be used. The specified torque numbers are developed by the fastener manufacturer so that the torque value will closely match the stretch values.
Crazyhorse is offline
djtalon
14
05-16-2006 10:21 AM
JanErik
2
04-20-2005 07:58 AM
ratman
28
12-21-2004 12:44 PM
formula31
12
02-18-2003 08:33 AM
CN24
3
08-23-2002 06:48 PM
