Electric brakes
Old 03-04-2007 | 09:09 PM
H20 Toie's Avatar
Default Electric brakes
I just had the electic over hydralic conversion done on my Myco trailer and wow what difference, i should have done that a long time ago.
H20 Toie is offline
Old 03-04-2007 | 10:15 PM
Payton's Avatar
Charter Member #927
What parts did you use?
Payton is offline
Old 03-05-2007 | 08:18 AM
plumbers crack's Avatar
Talking
I just converted my new trailer from surge to Electric/hydraulic.I used a Acti Brake pump with buit in tank,simple hook up and it flows alot of fluid and produces 1400 # of pressure.It really feels good knowing you can stop!!
plumbers crack is offline
Old 03-05-2007 | 08:44 AM
rickdarling's Avatar
Dan,
Did Saul at Accurate do it?
rickdarling is offline
Old 03-05-2007 | 08:48 AM
H20 Toie's Avatar
Originally Posted by rickdarling
Dan,
Hi Rick,
yes he did.
H20 Toie is offline
Old 03-05-2007 | 09:47 AM
Yamaha 225's Avatar
Hi.
Is the electric over hydraulic so that an electric signal from the brake lights actuate a solenoid which allow pressurized brake fluid go into the regular hydraulic brakes? What senses the retardation and adjust the amount of brake pressure to the brakes? Is it a G-forze sonsor or something?
We don't have that kind of brakes here. I am thankful for a discription.
:-) Erik
Yamaha 225 is offline
Old 03-05-2007 | 10:14 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by Yamaha 225
Hi.
:-) Erik
You can buy all the parts here:
www.championtrailerparts.com
There is a brake controller in the truck, that is actuated by your brake pedal. The controller then sends a varying electric voltage back to your braking system on the trailer. The potentiometer in the brake controller allows you to increase or decrease the electrical DC voltage sent to the trailer actuator, which allows you fine tuning for your brake system based on load and conditions. You can also set, and lock your brakes if needed. There is a battery on the trailer, and a break away cable from the truck, as such if your trailer breaks away from the truck, the battery system on your truck applies the brakes in an emergency.
Sydwayz is offline
Old 03-05-2007 | 10:26 AM
H20 Toie's Avatar
here is the pic of the conversion, you don't even notice that it's there looking at the trailer from the side.
Attached Thumbnails Electric brakes-dsc03148.jpg   Electric brakes-dsc03149.jpg
H20 Toie is offline
Old 03-05-2007 | 11:11 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Is that unit COMPLETELY sealed from water/weather?? If it gets wet due to a unplanned splash at the launch ramp, or whatever, your brakes are going to go haywire. It may be better to have that mounted higher, maybe up on the winch post.
I do like the way it looks.
Sydwayz is offline
Old 03-05-2007 | 11:38 AM
H20 Toie's Avatar
yep it is completely sealed. it will get wet i have had that part of the trailer underwater a couple of times
H20 Toie is offline
