Bow Lift
Old 03-04-2007 | 09:24 PM
Default Bow Lift
I have a 2000 Wellcraft Excalibur with a 565 cui engine put a bravo XR on it with a 26 pitch Bravo prop and can't seem to get enough bow lift any thoughts?
perform330 is offline
Old 03-04-2007 | 09:48 PM
BY U BOY's Avatar
check the hull for a hook use a straight edge to find if you have one.
BY U BOY is offline
Old 03-04-2007 | 10:46 PM
What do you mean by hook?
Old 03-05-2007 | 06:25 AM
Payton's Avatar
Charter Member #927
If you place a 4' or longer straight edge on the bottom of the boat. If it is tight at both ends and you see some daylight in the middle you have a hook. If there is daylight at either end, you have rocker.
I had less than an 1/8"hook in the last 4" of my hull. I removed it with a belt sander then repainted the area. It made a huge difference in how much of my hull was in the water when running .
Payton is offline
Old 03-05-2007 | 08:38 PM
What size boat????
Griff is offline
Old 03-06-2007 | 08:04 AM
Griff,
Its a 26.5 I added 280 K trim tabs as well.
Old 03-07-2007 | 12:27 AM
How deep is the propshaft below the bottom???
If the drive is at stock depth it should be deep enough, but maybe not. Lowering it 1" with a drive spacer will give more leverage to lift the bow. Prop work will also help. Add cupping in the right place and rake angle.
Griff is offline
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
PARADOX
04-28-2008 11:30 AM
Dtile
8
10-02-2006 11:46 AM
cstobe
0
04-11-2006 11:06 PM
pullmytrigger
Prop Talk
2
10-17-2005 01:35 PM
