28' straight V bottom X-dim. >
Old 03-10-2007 | 12:25 PM
littledcsrodshop's Avatar
Default 28' straight V bottom X-dim.
I am curious what you guys are running for X-dimmension on 28' ( or so ) single engine Straight V bottoms ( no pads , steps , or notches )
Please specify the boat , Weight , Cabin or no cabin , What drive , Prop , extension box or not , ect.........
What are you guys running ? & what kind prop slip #'s , if you don't know the slip#'s give the rpm , prop pitch & GPS ( only )speed
Thanks , Scott
littledcsrodshop is offline
Old 03-10-2007 | 01:12 PM
Comanche3Six's Avatar
#3 Ssm 21.5"
Comanche3Six is offline
Old 03-10-2007 | 02:08 PM
Originally Posted by Comanche3Six
#3 Ssm 21.5"
What does a # 3 measure shaft to shaft ?
Old 03-11-2007 | 01:29 AM
Wild Card 09's Avatar
the Flightmaster
25 Outlaw with 3" lift Imco box. Notched transom. 4 1/2" from pad to propshaft. XR drive. 525 power, 80 mph.
Wild Card 09 is offline
Old 03-11-2007 | 05:33 AM
28 cigarette , single trs , propshaft is even to the keel.. do not have any other info other than it handled great when she ran ahh , like 6 years ago...
open87 is offline
Old 03-11-2007 | 02:55 PM
The standard X for a single engine 28 Pantera without a notch is 17"--thats what Jo told me.
The propslip varies depending on power and prop used between about 12% and 18%
Griff is offline
Old 03-12-2007 | 09:09 PM
Yeah I know that Jo likes to run their non notched 28's about 5 - 5 1/4 below the V.
Old 03-12-2007 | 09:19 PM
I am asking this obvoisly for my 28 Saber. Which as far as comparison it would probably be very similar to the setup on a 28 Pantera ( no notch transom ) & generally Jo sets them up with Bravo 4 blades.
The boat should come in around 5000# & will probably end up with a Konrad on it. I am just woundering with all of the new 5 & 6 bladers that are out now , am I best staying conservitive with the X & running a 4 blade bravo or going just a touch higer & running a 5 or 6 blade ?
Keep in mind the boat is a pleasure boat with a cabin & is a non step V that will need bow lift. Just trying to get some opinions to kick around at the moment.
Old 03-12-2007 | 09:45 PM
Elite Marine's Avatar
If you need any help or direction on the Konrad. Let me know. It's a very complete system, but there are things to be aware of.
Also, if I can help with the purchase, I'd like to be your distributor of choice.
Kirk
Elite Marine is offline
Old 03-12-2007 | 10:04 PM
Kirk
Thanks Kirk, Where did your X end up at ? I would assume somewhere around 4 1/2 - 5 Due to the fact that you are running a box.
cuposterchild
Superboat
12
04-22-2009 06:50 PM
frinaudo
Fountain
5
06-03-2007 10:32 AM
Croozin2
Cigarette
12
03-28-2007 08:26 AM
jawbreakerkid
Cigarette
6
02-01-2006 12:53 PM
Wild
3
03-21-2005 07:32 PM
