what valves are in a stock gen 6 502efi >
Old 03-14-2007 | 12:41 AM
HiPerf2000's Avatar
Default what valves are in a stock gen 6 502efi
what exhaust valves are in a stock gen 6 502efi ? inconel or severe duty ?
HiPerf2000 is offline
Old 03-14-2007 | 08:52 PM
Inconel made by Eaton. Not the best, but they are decent quality.
Noise Pollution is offline
Old 03-16-2007 | 12:01 AM
HiPerf2000's Avatar
i'm buying a used set of heads and figured i'd re-valve them before install. do i need to go with inconel on a stock motor ?? or will manley stainless severe duty work ??
thanks
Old 03-16-2007 | 07:26 AM
thanks
If the heads came off a gen 6 motor they should be Inconel exhaust valves. If your buying new valves, Definitly go with the Inconel for the exhaust. They take the heat better. Who ever does your valve job make sure the you get a seat with of .090 - .100 minium. It helps to transfer the heat.
Old 03-16-2007 | 02:37 PM
You save some $$$ if you use the Ferrea super alloy's. They are similar to the Manley inconnels.
http://www.ferrea.com/
Griff is offline
Old 03-16-2007 | 04:10 PM
BY U BOY's Avatar
i think that is what came in my zz502/502 heads.
BY U BOY is offline
Old 03-16-2007 | 08:59 PM
Forgot to mention. Also have new exhaust seats put in. They have a tendency to fall out.
racinfever
2
03-29-2008 02:16 AM
cooltoys61
16
06-21-2005 08:46 PM
26sonic
2
05-16-2003 06:49 AM
26sonic
2
04-01-2003 08:15 PM
Dave1972
4
03-03-2003 05:33 PM
