Help With Utility Quad and Rhino >
Old 03-15-2007 | 01:03 PM
BigMike's Avatar
Default Help With Utility Quad and Rhino
I bought 60 acres this past weekend and it is too big to walk. I want to buy an inexpensive utility quad this weekend to motor around on. I would like something in the 450 cc range with 4wd and an auto tranny for the wife. I already have a 2007 Yamaha YFZ 450 but it is not a good farm vehicle (it will be when my MX track is finished!). I know very little about utility quads. Any help would be appreciated. I am also looking for a Rhino/Mule type of vehicle as well. Seems like the Rhino's are the sprotiest of the bunch and the Mule/Gators are more the workhorses. Let me know what you think.
Mike
BigMike is offline
Old 03-15-2007 | 04:19 PM
ACTIVESHACK's Avatar
Check out the Polaris Ranger. Its the fastest of them all
ACTIVESHACK is offline
Old 03-15-2007 | 04:38 PM
tblrklakemo's Avatar
SeaRay Sundancer
Most of the big manf. make a comparable quad. The kubota RTV is the best utility vehicle.
tblrklakemo is offline
Old 03-15-2007 | 04:42 PM
THEJOKER's Avatar
Mine is being built now , ships in 2 weeks! 500 cc - locking rear - 4x4 - automatic - hydraulic dump bed - winch - 2 or 4 seater.
Key Features
Convertable 4 seats/2 seats
Powerful 25KW, 500cc CF Engine
Lockable Limited Slip Differential
Switchable 2WD/4WD
High/Low Range
Hydraulic Rear Bed
Engine
Size: 500 cc CF Water Cooled
Power: 32 HP / 25 KW
Performance
Speed: 40MPH / 60KPH
Fuel Economy: 25 mpg / 9.41 liters/100 km
Fuel capacity: 6 GAL / 20L
Load Capacity: 1,330LBS / 603KG
Drive Train
Transmission: Automatic,
CVT Push Button Command 4 wheel drive
Driveline: Shaft Drive
Chassis and Suspension
Front : Independent MacPherson Struts
Rear : Independent, Double Wishbone
Brakes, Rim and Tire
Front & Rear Brakes: Hydraulic disc
Front Tire: 25 x 8-12
Rear Tire: 25 x 10-12
Dimensions
OA Size: 305 x 141 x 80mm
OA Weight:: 1,014LBS / 460KG
Shipping info: 8units/20¡¯ 16units/40HQ
THEJOKER is offline
Old 03-15-2007 | 07:38 PM
BigMike's Avatar
WTF is that? Chinese? Looks good.
Mike
BigMike is offline
Old 03-15-2007 | 08:04 PM
THEJOKER's Avatar
My buddy graduated from Ga Tech w/ an engineering degree and moved to Shanghi. He designed them and builds them there.
THEJOKER is offline
Old 03-15-2007 | 08:14 PM
THEJOKER's Avatar
This is his other design. 120 mph - SICK!
Attached Thumbnails Help With Utility Quad and Rhino-1800cc-vw-power-baja-go-kart-gk-1800-.jpg
THEJOKER is offline
Old 03-15-2007 | 08:26 PM
Wardey's Avatar
Mike, I too am looking at the Rhinos. My Bro-in-law owns a Yamaha/Polaris/KTM dealership and he told me to go with the Polaris. It is true 4x4 where as the Rhino is kinda like limited slip. I am not going to keep it stock so I am going with the Rhino just because I think they look better. He still says the Polaris is the better machine and if he was buying one, he would go Polaris. Tres Martin has a Polaris Utility up on his ranch in Ocala I beleive, and we took it out one eve and it was nice. More work oriented than the Yamahas but he and Jackie use it for the ranch use. But the Rhinos can be tuned to run 65mph !!! Dave
Wardey is offline
Old 03-15-2007 | 08:29 PM
THEJOKER's Avatar
What do the Rhinos cost , loaded?
THEJOKER is offline
Old 03-15-2007 | 08:34 PM
THEJOKER's Avatar
http://www.polarisindustries.com/en-...Comparison.htm
Loaded Polaris $ 13,000
THEJOKER is offline
