Go Back  Offshoreonly.com > Owners Forum > Banana Boat
Top Banana question on boat # 6 >
Old 03-15-2007 | 08:10 PM
Default Top Banana question on boat # 6
Charlie
I was looking at the pics at the cockpit I only see one morse control did that control both throttles and clutch? or did you have a second control? wondering how the older race boats were set up.
Josh
oldschoolfan is offline
Old 03-16-2007 | 08:14 AM
Top Banana's Avatar
Originally Posted by oldschoolfan
Charlie
Josh
One lever controlled both.
Top Banana is offline
Old 03-16-2007 | 08:18 AM
ok this may be a stupid question but is there any way to control the throttle w/out engaging the clutches? when using that style control?
Old 03-17-2007 | 12:19 AM
BattleCry's Avatar
Yes. If you pull out on the control in while in neutral, you are able to use just the throttle and not engage the clutches.
BattleCry is offline
Old 03-17-2007 | 08:37 AM
I dont think that works on the morse style controls that Top Banana had.
Old 03-17-2007 | 03:58 PM
Top Banana's Avatar
Charlie
Josh
Post the pic that you are referring to.
Old 03-17-2007 | 05:47 PM
This pic here.
Old 03-17-2007 | 07:15 PM
Top Banana's Avatar
This pic here.
Those controls could be grabbed around the joint and pulled out....that put the trans in neutral and you could rev the motors up.
By popping them back in, it then gave you FWD - N - REV and by pushing them far enough ahead, it gave you the throttles only.
They worked very cleanly and could be used with no problem for racing.
Don't forget I didn't use a throttleman in that boat, I drove, trimmed and throttled myself.
With the three compasses, I could put a navigator on either side or sometimes we put in one different compass as a test for Ritchie, to see how it lasted as compared to the others.
With that boat being so fast and so small, most of the navigating was done by looking quickly at the compass for a reading and then picking out a cloud on the horizon. I would aim for the cloud until I felt I needed another check and then do it all over again.
Most races lasted 2 to 3 hours
Old 03-17-2007 | 07:29 PM
Thanks for the help Charlie. I have another question while you are here. Do you have any of the low windsheild screens left in storage.
thanks
Josh
PJRIZ
03-01-2020 03:23 PM
oldschoolfan
Classic Offshore
0
01-07-2007 09:22 PM
lucky strike
Classic Offshore
1
11-04-2006 08:32 PM
ratman
10-09-2006 07:14 PM
Air Dog
Banana Boat
18
03-17-2006 05:44 PM
