thick Exhaust gasket ? >
Old 03-15-2007 | 08:22 PM
TomFTM's Avatar
Default thick Exhaust gasket ?
Does anyone know of any manufacture that makes a exhaust gasket that is at least 1/8 (.125) thick. The gasket is round 2.15 inch big block chevy . I spoke to Mr. gasket and they dont have it. I have also checked my felpro books and they don't offer it.
The problem I'm having is the headers are hitting the valve covers .The headers are CMI split tubes . The valve covers are tall cast aluminum KE's. Replacing the valve covers is not an option, due to they are newly painted , and they are needed for the clearance for the stud girdles . I know I can grind the corner of the valve cover a little ,but I dont want to have to grind to much material . This is for a twin engine side by side tall deck blocks so exhaust spacers will cause the headers to hit.thanks for your help.
Tom
TomFTM is offline
Old 03-15-2007 | 08:26 PM
Elite Marine's Avatar
Double up a regular gasket!!
Elite Marine is offline
Old 03-15-2007 | 08:31 PM
TomFTM's Avatar
Pantera 28, I thought of that ,but I think that will probably blow out . Have you had any luck doing that?
TomFTM is offline
Old 03-15-2007 | 09:28 PM
Tinkerer's Avatar
Use the Mr Gasket grafite gaskets and double them up
They have wire mesh built in.
I have used them for years and have never blown them out.
Make sure you keep the header bolts tight and it shouldnt be a problem.
Tinkerer is offline
Old 03-16-2007 | 11:20 AM
TomFTM's Avatar
Has anybody else tried running two gaskets .
TomFTM is offline
Old 03-16-2007 | 11:56 AM
BajaExpress's Avatar
Tom, Try CV parts, most of the high performance machine shops use their parts. I use the thick on my drag boat and have had no problems, Beware, you may have to retorque from time to time the header bolts. Is there a way you could heat up the exhaust and bend slightly away from your valve cover?
BajaExpress is offline
Old 03-16-2007 | 12:11 PM
TomFTM's Avatar
I cant change the pipes in anyway , they are powdercoated.
TomFTM is offline
Old 03-16-2007 | 05:46 PM
cuda's Avatar
I just saw a pair of exhaust spacers for sale somewhere, check in the Swap Shop on here. I imagine that's what they were made for.
cuda is offline
ohmthis
3
08-01-2007 11:18 AM
gripit
2
05-18-2007 05:31 AM
rv
7
01-05-2007 02:05 PM
duunoit
5
06-14-2006 05:04 AM
GoCiggie31
4
10-24-2005 11:49 AM
