Shift cutout switch...Bravo? >
Old 03-18-2007 | 04:55 PM
Default Shift cutout switch...Bravo?
Do Bravo drives need or use shift cutout switches?
jdub is offline
Old 03-18-2007 | 06:26 PM
Biggus's Avatar
no
Biggus is offline
Old 03-18-2007 | 07:10 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
the drive has no need for a switch but in the mercury engine circuit there is a neutral safty switch . the drve must be in neutral for engine to start
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 03-19-2007 | 05:38 AM
thanks
jdub is offline
Old 04-09-2011 | 07:12 PM
I just cracked one of my Shift Cutout Switches (Alphas). 3 questions:
1) Is the purpose of this switch so you don't start the engine in gear?
2) What is the logic? Closed circuit disables ignition? ...or open circuit disable ignition?
3) If open disables, hardwiring will defeat that check? (Not that I want to, but I want to be able to run while waiting for the part).
Thanks.
242LS is offline
Old 04-09-2011 | 07:47 PM
Default Fixx
Thanks.
the purpose of the cutout switch is so you can pull the drive out of gear, it kills the engine for a split second..if their not hooked up the drive will stay in gear even tho the control is in neutral.
thats if this is the switch on the shift cable assenbly...all you have to do is shut the engine off before you try to take it out of gear,once out you will have to restart and select your other gear...it will be a pain to dock with out this switch..
FIXX is offline
Old 04-09-2011 | 11:28 PM
Got it - thanks. That helps.
242LS is offline
Old 04-10-2011 | 08:41 AM
Reading this thread, do I sense a difference of opinion.
1) Switch that is connected to the starter circuit.
2) Switch that is connected to the ignition circuit.
Which is the correct? Or both? Wiring is right up my alley and designing/building a wire harness to perform would be easy.
ROTAX454 is offline
Old 04-10-2011 | 04:54 PM
Registered User
My buddy needed it on his alpha 454 combo. My bravo 454 didnt need it. Must be how the gears are cut????
bigblue is offline
Old 04-10-2011 | 05:38 PM
Too Stroked's Avatar
The Bravo drive uses Cone Clutches to shift. The Alpha is pretty much like an outboard - just jamming the gears together. That's why you need a shift / ignition interrupter when you shift. It allows the gears to mesh safely.
Too Stroked is offline
