675Keith Eickert
Old 03-21-2007 | 08:49 AM
Default 675Keith Eickert
Which gas do you use on a 675 Keith Eickert engine.
Any ideas?
Michael Foerster is offline
Old 03-21-2007 | 12:34 PM
JIMKID Motorsports's Avatar
ask gino just kidding
JIMKID Motorsports is offline
Old 03-21-2007 | 05:05 PM
I use 93 octane in mine.
JoeD is offline
Old 03-21-2007 | 05:34 PM
Strip Poker 388's Avatar
Rob
I would think any engine up to 1000hp should beable to run on 93.unless its a lower budget built motor and is turned up to make the power
Strip Poker 388 is offline
Old 03-21-2007 | 06:03 PM
Any ideas?
I ran 93 in mine w/o any problems. 700ft above sea level, hot & humid summers. The KE675 is pretty conservative only making approx 4lbs boost.
NASCAT is offline
Old 03-21-2007 | 08:02 PM
Jassman's Avatar
92 Octane will work without damage,93 preferred.
Jassman is offline
Old 03-22-2007 | 05:16 AM
Actually I was just checking thru my papers and came across the spec sheet for the Eickert 675 and is says a "minimum of 89 octane"---if you would like I can fax the sheet to you just pm me your fax number.
JoeD is offline
Old 10-08-2010 | 10:02 AM
Cigaretteman's Avatar
Hi Joe,
I know this tread is very old.
Do you still have the spec. sheet for that engine? I would love to have a copy of that. Any chance you could scan it and mail it to me or maybe post a picture of it here?
Cigaretteman
Cigaretteman is offline
Old 10-09-2010 | 09:41 AM
When I get back to my office next week I will scan and post
JoeD is offline
Old 10-09-2010 | 10:01 AM
mikes280's Avatar
the engine calls for 89 or better ,you can run 89 but if i could get it i would run better then 89 just to be safe.
mikes280 is offline
